12 volt cig lighter not working - E100 sedan - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2011, 02:48 AM   #1 (permalink)
View e100's Photo Gallery
Australia 12 volt cig lighter not working - E100 sedan
Hello
My 12 volt cigarette lighter doesn't seem to be working in my e100 sedan. I have checked the fuses and I believe they seem to be fine but the 12 volt lighter is not working. Even the green illumination ring light around it doesn't seem to be working either.
Any ways to fix this?
Could be a fuse problem don't know??
thanks
e100 is offline   Reply With Quote
Old 01-23-2011, 01:56 PM   #2 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Welcome to the forums! It could be the cigarette lighter socket that is at fault. The same thing happened to me a little while ago when I tried to use a cheap 12v air compressor from Repco. It would keep blowing my fuses, so I took the compressor back, swapped it for another one, and the new one didn't blow a fuse, but instead it blew the entire cigarette lighter socket . Made a quick trip to the junkyard to get another socket and it was all fixed (didn't use that crappy air compressor again though). Other than a blown socket, check for corrosion on the connections
Old 01-23-2011, 02:28 PM   #3 (permalink)
Token Aussie
Hiro Protagonist's Avatar
Gameroom cash: $179500
View Hiro Protagonist's Photo Gallery
Also check to make sure the securing ring on the lighter socket hasn't come loose. After years of using car-chargers etc in my socket it had slowly worked loose (from constant twiddling) and caused the socket to lose power (also blew the fuse in the process). Just take off the centre-console trim and ensure that everything down there is plugged in properly and tight.
Charlene - 1997 AE102 sedan: FXGT of awesome
Billie - 1981 KE55 sedan: GOOOONNNE
Rosie - 1986 AE82 Twincam Seca: Converted into garage space
Charlie - 1988 ST62 liftback: Moored in the garage
Lexi - 1995 JZZ30 GTTL: Hunting n00bs in Skylines and SS Commodores
Hiro Protagonist is offline   Reply With Quote
