Washer nozzles - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-25-2011, 01:06 PM   #1 (permalink)
View 93geoprizm's Photo Gallery
Washer nozzles
Mine really piss me off. So since I live in MI and get all this salt and crap on the roads, all the cars driving just throw all that garbage on the windsheild, which is ok, but now when youre frigging washer nozzles are not working and the wiper is trying to clean the windshield but messes it up even more. I have tried cleaning them and no luck. Ive gone to junkyards and bought some, they work for a lil bit and then stop again. I dont know what the heck to do anymore. Can we even buy brand new ones for our cars anymore? No im not getting one from a stealership for $50 a piece
93geoprizm is offline   Reply With Quote
Old 01-25-2011, 03:02 PM   #2 (permalink)
on full afterburner
Gameroom cash: $1345597
Just order them online from one of our supporting vendors.
Surely would be cheaper than going to a dealer.
Old 01-25-2011, 04:03 PM   #3 (permalink)
Ive done a search, havent come across one selling it
Old 01-25-2011, 04:06 PM   #4 (permalink)
BoyYota's Avatar
Gameroom cash: $138400
View BoyYota's Photo Gallery
Did you try cleaning them with a needle?
94 Prizm LSi 1.8. Auto and still quick as hell.
BoyYota is offline   Reply With Quote
Old 01-25-2011, 04:06 PM   #5 (permalink)
BoyYota's Avatar
You can buy the tacky LED ones at Advance/AutoZone for $20 and just leave the light disconnected.
The Following User Says Thank You to BoyYota For This Useful Post:
GTChink (01-25-2011)
Old 01-25-2011, 06:17 PM   #6 (permalink)
GTChink's Avatar
Gameroom cash: $105050
View GTChink's Photo Gallery
oh good idea..I broke one of mine
1994 Corolla
GTChink is offline   Reply With Quote
Old 01-25-2011, 06:23 PM   #7 (permalink)
Gameroom cash: $323845
View cipher93's Photo Gallery
Are you sure it's the nozzle and not the motor or a blockage in the line?
cipher93 is offline   Reply With Quote
Old 01-25-2011, 08:33 PM   #8 (permalink)
Gameroom cash: $202300
View zppeacock's Photo Gallery
according to toyodiy the washer nozzles are like $25 each. You could have some junk in your tank that keeps on clogging them up.
zppeacock is offline   Reply With Quote
Old 01-25-2011, 09:45 PM   #9 (permalink)
yup thats the first thing i did
lol yea i started searching around and came across those, hey if it works, i dont care, not like ima hook em up and try to lightem up at night
im not sure what it is, as soon as i put a new one, they work for a little bit and then go bad
Is there something i can pour in there to get rid of the crap?
Old 01-25-2011, 10:43 PM   #10 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
remove the washer bottle from the car, wash it out. pop the lines off the nozzles, blow through or wash the lines out with water, back flush the nozzles (lol), wash the pump out, put a little inline gas filter on the line out from the pump to the nozzles if you're paranoid.
Old 01-25-2011, 11:58 PM   #11 (permalink)
Before "THE WRECK"
sequoiasoon's Avatar
iTrader Score: 7 reviews
View sequoiasoon's Photo Gallery
That's the only thing I never did on mine and now I'm like why didn't I think of that. Mine had clogged numerous times from junk in the system. I replaced a bunch of the lines. Most of my issues came from when I had used the Rain-X washer fluid. That crap used to leave small stains all over my car that had to be cleaned off (and I like normal rain-x). I'm sure the inside of my lines looked the same and that's what clogged mine. Now I need to do that for the Sequoia and my Sonata. I didn't do it on the Sonata yet but the Sequoia and the Corolla I also did a "heated" version by wrapping a section of vacuum line around the upper radiator hose. Helped a lot (in cold especially) to get some warm fluid to clean the window. No the windshield never cracked as it didn't get that hot and yes the car need to be warm first to get that so that initial ice in the AM still relies on the washer fluid properties for anti-ice, yes it probably added to my clogging by cooking it when the car sat just after shut down. Some used to seep out from nozzles during hot weather at that time but the benefits outweighed the cons.
OP-
PM me your address info. I think I still have some that you can have. I might have some from a Sequoia also that had the "wide mist" version also that covered the whole window not just two spots.
'93 Corolla getting parted out. Will be scrap REAL SOON so TELL ME WHAT YOU WANT OR NEED!!! Pictures and videos here http://s700.photobucket.com/albums/w.../parts%20left/
sequoiasoon is offline   Reply With Quote
Old 01-26-2011, 02:05 AM   #12 (permalink)
Gameroom cash: $199666
View jkg065's Photo Gallery
If all else fails,
Google: WYPO Tip Cleaner
Used primarily to clean oxy-acetelyne welding/cutting torch tip orifices. Assorted stainless steel wire 2" lengths with ridges. I have found using the 1/2" non-ridged tips to clean out the washer nozzles works quite well. ALWAYS start with the smallest diameter length, DO NOT INSERT THE RIDGED PORTION OF THE WIRE INTO THE NOZZLE TIP AS IT WILL ACT AS A FILE AND EXPAND THE OPENING! Using slight movement with the solid or non-ridged portion of the cleaner inserted in the nozzle tip one may be able to adjust the tip to point in the appropriate direction. DO NOT INSERT OR FORCE ANY TIP CLEANER THAT IS OVERSIZE INTO THE NOZZLE. Your local welding equipment supplier should have the tip cleaners at a very very affordable price.
'04 Nissan Altima 3.5SE
'08 Corolla CE (wife's)
jkg065 is offline   Reply With Quote
Old 01-26-2011, 07:23 AM   #13 (permalink)
Bitter's Avatar
OP-
Good idea about wrapping around the rad hoses...but I think I'll wrap around the heater lines with some flexible copper. It'll get hot faster there. I had wanted to do the hot-shot heater system but they're $$$.
Old 01-26-2011, 09:28 PM   #14 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
And to add to jkg's post- Use the tip cleaner to re-aim the nozzles if they are too low or high. They are in a ball and socket arrangement so they can be moved.
-SP
