Originally Posted by BoyYota
I'm pretty sure the doors are the same because the door panels look the exact same. The inside and outside handles are the same. I guess you'd have to compare them side-by-side to really tell but I'm pretty sure everything between the font end and the rear end of the body is the same.
I thought the same thing about the AE101 Toyota Sprinter (which is basically the JDM equivalent of the Geo Prizm) as the door panel looked
identical to mine, as did the rest of the interior, so I decided to buy the interior strip that goes along the top of the door panel as mine had a slight tear in it. When I got home, I fitted it and noticed that there was about a 1" gap between the strip and the interior mirror cover. Curious, I took measurements of my door then measured the door of the Sprinter the next time I was at the junkyard. Sure enough, the Sprinter door was slightly shorter.
I also noticed that the metal part of the rear deck is about an inch longer than the Corolla, so the rear deck tray is longer. Apart from that, the rest of the interior was exactly the same. As for the outer panels/parts, the only interchangeable parts I could see would be the front bumper, rear bumper, mirrors and mud flaps.
