Timing Belt ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-08-2011, 07:15 PM   #1 (permalink)
View vkray's Photo Gallery
USA Timing Belt ?
Hey I have 1996 Corolla that has just turned over 76,000 miles, I was wondering when I should do the timing belt replacement?
How much should I expect to pay?
Thanks
vkray is offline   Reply With Quote
Old 02-08-2011, 08:27 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $995375
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
You're about due for a new one now.
The Jedi Speeder at CarDomain
Old 02-08-2011, 08:33 PM   #3 (permalink)
Gameroom cash: $816401
View zythr's Photo Gallery
Thanks
Hey, Now:} Cost should not be too much but prices in your area may vary. It is also wise to have the seals (oil, crankshaft, camshaft) replaced and the water pump as well (since it is behind the timing belt). Ball park figure around $500 for everything.
zythr is offline   Reply With Quote
Old 02-08-2011, 10:14 PM   #4 (permalink)
Thank you guess I better check out pricing
Old 02-08-2011, 10:51 PM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Timing belts average about $45-$55.00. About 2 1/2 -3hrs of labor. rates very from $65.-$75.00/hr.
Since you're apying someone to do this, if your water pump isn't giving you trouble and you're not leaking oil, via crank or cam seals, I would leave them alone.
Old 02-09-2011, 08:46 AM   #6 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
I'll contradict Jedi in one area- Replace the crank seal. Beacuse it spends its time BATHED in hot oil it will be hard as a rock and may not be leaking now but it will be before its time for the next belt. Its a cheap part and easy to install with the belt off. Water pump has a good longevity and cam seals only get oil splash. (and easy to replace at any time!)
-SP
