Originally Posted by kickfli12
cv joints pop/click while turning.
True, but I was referring to the *boots*, not the joint itself.
Originally Posted by TurkeyHead
Hows the squeal of the cv joints?
Difficult to describe a sound, but it is rather low pitch, sometimes a bit pulsating. It is rubber being squeezed. You can clearly tell that it is changing with the speed of the car.
Does the sound change if the car rolls and you put the transmission in neutral and then rev the engine a bit? If it does, then it is not the boots.
