97 corolla almost stalls taking left turns - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2011, 08:57 PM   #1 (permalink)
View Richburg's Photo Gallery
I have a 97 toyota corrola with a 1.6 littere engine 206k miles. It almost stalls while im taking left turns intermittantly. It has no codes and Ive watched the data stream on my scanner. All the sensors are good fron the tps, map, IAC, coolant temp, IAT, Even the fuel trim is good(that was my first concern) Im ripping my hair out trying to figure this out....Please help!
Richburg is offline   Reply With Quote
Old 02-20-2011, 09:28 PM   #2 (permalink)
Gameroom cash: $202300
View zppeacock's Photo Gallery
I have the same problem, mine only happens above 15mph hard left turn. You can turn it any which way parked or at idle and it wont reoccur.
zppeacock is offline   Reply With Quote
Old 02-20-2011, 09:37 PM   #3 (permalink)
Ya... When I stop at an intersection and take off going left it stalls or allmost stalls I take my foot off the gas and get back into it it doesnt stall..Just starts to.
Old 02-20-2011, 09:38 PM   #4 (permalink)
Gameroom cash: $323345
View cipher93's Photo Gallery
Fuel pump is on the left side of the tank, and when you make left turns the fuel is running away from the pump/pickup. Does it make a differences with the amount of fuel in the tank? If it gets worse when it's lower, your fuel pump is likely wearing out or the screen around it is clogged up.
cipher93 is online now   Reply With Quote
Old 02-21-2011, 07:13 AM   #5 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
had the same problem too, even with a full tank and new pump and new pickup screen.
Bitter is online now   Reply With Quote
Old 02-21-2011, 09:25 AM   #6 (permalink)
Woodyg's Avatar
Gameroom cash: $138765
View Woodyg's Photo Gallery
if ou are sitting in the driveway and turn the wheel to the left does it stall/want to stall?
2006 Vibe, White, 1zzfe, auto ( Toyota type IV), AWD, PW, PL, CC, AC, 161,000(5/12/2012)
1998 Camry LE, 4 door, Puke Green, I4(5S-FE), CA Emissions, Auto(A140E), 122k(3/22/2012), AC,CC, ABS, Built in Japan 04/98. Grandmas old car(acquired 7/22/2011), work= precat Denso A/F sensor, NGK wires.
Woodyg is offline   Reply With Quote
Old 02-21-2011, 07:44 PM   #7 (permalink)
anyone?
Old 02-21-2011, 07:52 PM   #8 (permalink)
no
Old 02-21-2011, 10:20 PM   #9 (permalink)
Bitter's Avatar
I'm pretty sure its some kind of fuel pickup problem. Mine has always done it, even when I replaced the original pump (it did fail), the 1st one was loud as hell and died on left turns like it used to do. Got a different pump, was quieter and left turn problem still. I tried different fuel strainers and installed the pump a few times, I could watch it go dead lean on the wideband and checked that it had constant voltage. I think somehow the well that the pump sits in sloshes its fuel out on left turns and then runs dry. It can happen even on a wide left turn at higher speeds, its related to lateral G's not the sharpness of the turn.
