Instrument cluster replacing lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-23-2011, 11:52 PM   #1 (permalink)
View d12boy420's Photo Gallery
I am having trouble replacing lights in my 95 dx instrument cluster. I cannot get the brown base to come off the light as it seems it is contact welded into the base. Would it be easier to solder led lights to the board instead of getting the bulbs out of the base?
d12boy420 is offline   Reply With Quote
Old 02-24-2011, 12:58 PM   #2 (permalink)
GTChink's Avatar
Gameroom cash: $105050
View GTChink's Photo Gallery
Try spraying some wd40 in between the bulb and the base...then yank it. Wait, or was it where you pushed the bulb in a bit, then twist, and it should come out? I forget..LOL
1994 Corolla
GTChink is offline   Reply With Quote
Old 02-26-2011, 08:09 AM   #3 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
so you removed the cluster, on the back, the bulb sockets, to remove you twist, then pull. Now some of those sockets were changed throughout the years. And the older sockets had terminals off to the side. I had to break a few bulbs to get them out of the sockets. Later they changed the sockets so the bulbs could be replaced easier. But basically they use 194 bulbs, and the older sockets you have to bend the wires on the bulb and make them stick out to make contact with the metal terminals. I used to have a pic oh these sockets somewhere, if I find it, I will post it up
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 02-26-2011, 07:35 PM   #4 (permalink)
96 Toyota Corolla
kickfli12's Avatar
Gameroom cash: $133700
View kickfli12's Photo Gallery
i just happened to have a bulb here next to me and made this Bulb replacement DIY for you
FIRST: find the little metal bar things on the contacts
SECOND: get a sharp object and pry them away from the contacts
THIRD: wiggle the bulb out of the socket
FOURTH: replace bulb and youre done. easy as that =) hope it helps
i have a factory spoiler for sale.
http://www.toyotanation.com/forum/66...ake-light.html
kickfli12 is offline   Reply With Quote
Old 02-26-2011, 07:52 PM   #5 (permalink)
Thanks, I appreciate it didn't want to break them :P
Old 02-26-2011, 07:52 PM   #6 (permalink)
96 Toyota Corolla
kickfli12's Avatar
im glad i could help.
Old 02-27-2011, 09:35 AM   #7 (permalink)
trife96's Avatar
like I said, I had found some clusters had different sockets in them that won't need any modification. I was glad to find them because you don't need too bend wires and all and they take the led bulbs. But they are hard to find. I pulled out a lot of instrument clusters in the junk yard till i came across them
Old 02-28-2011, 08:03 AM   #8 (permalink)
Gameroom cash: $128158
View jawsofire's Photo Gallery
I had the same thing. Ended up breaking a couple of them. I ended up replacing them with the quick change sockets.
jawsofire is offline   Reply With Quote
Old 03-04-2011, 01:27 AM   #9 (permalink)
View gameguru1360's Photo Gallery
have you tried replacing those bulbs with high powered LEDs??
Totaled 1996 Corolla DX
2009 Nissan Altima 2.5S with Takeda SRI, stock dual exhausts, mesh grille
LED bulbs for dome/map/turn signal/tail light/3rd brake light/back up bulbs
gameguru1360 is offline   Reply With Quote
Old 03-05-2011, 12:11 AM   #10 (permalink)
My car's name is Kerolla!
View brown0809's Photo Gallery
This is what it looks like after white LED replacement
I recently changed the LEDS to ones that shoot light to the sides as well as the top. Now the dark spots shown there are covered with light. I posted this one because I currently don't have a picture of the new ones yet.
A tip. Make sure the wires are touching the metal contacts on the base of the bulb before you twist them back into the cluster. This can be a pain.
brown0809 is offline   Reply With Quote
Old 03-05-2011, 11:27 AM   #11 (permalink)
Life's better in a Toyota
Callum3's Avatar
View Callum3's Photo Gallery
Hate to double post but, did you have to use resistors with those LED's and where did you get the new LED's that shine more light...I find it hard enough to find regular ones around here lol
Thanks Callum
03 4runner - 2UZFE - Beauty and a beast!
95 Corolla - 7AFE - 405,000kms running strong
76 Land Cruiser - FJ40 - Needs restoring
Callum3 is offline   Reply With Quote
Old 03-06-2011, 09:02 PM   #12 (permalink)
No resistor is needed. I got mine at http://autolumination.com/194.htm. I have the one that are second from the top.
This is what it looks like with the 6K white 9 LED bulbs. Not a big change, just some of the darker areas are now brighter.
The Following 2 Users Say Thank You to brown0809 For This Useful Post:
Callum3 (03-07-2011), swx1042 (05-12-2011)
