What year is your car? I have a 1993 Corolla with an exhaust leak near the flex pipe and I'm getting 27 to 30 mpg on a 3 speed transmission with no overdrive. The engine has 266700 miles on it. Since you did a recent tune up, the gas leak will be on your fuel lines.
There are 3 or 4 lines if I remember right. You have the main fuel line, the return line, the evap line, and the overfill line. If the car is old, likely there will be a small leak. Mine leaks at the overfill line and the return line. I changed all of them and I ordered from Schaumberg Toyota in Chicago land. One more thing, don't forget the gasoline tank. If the gas tank leaks, likely will be at the seam. Why don't you fill the gas tank to 5 gallons and drive to see if you get more milelage. This would test your gas tank or fill the tank full and drive a bit and jack the car up and check for dampness or wet spot around the tank. Also the the smell test. Good luck!
