Motor mount help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-25-2011, 12:36 PM   #1 (permalink)
View TurkeyHead's Photo Gallery
Motor mount help
Can someone help me find a write up for the pass right motor mount. I have it mostly apart but cant get the old mount off the shaft thats coming out of the motor. Help please!
Yes I do have the motor jacked up with a block of wood at the pan.
TurkeyHead is offline   Reply With Quote
Old 02-25-2011, 07:28 PM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
I'm hoping you mean you have it jacked up under the transmission.
Shaft coming out of the motor? Huh??
The main bolt that goes through the mount should just unscrew. Sometimes they do get rusty and the bolt will only come out with some torch action. OR if the bolt turns, the nut on the other end may be turning too. I think its welded to the mount.
-SP
Old 02-25-2011, 07:38 PM   #3 (permalink)
You asked for it...
View azcorolla's Photo Gallery
IIRC, You've got three bolts on the fender and one sticking straight down on the motor side of the mount. Then from underneath there's two more sticking up. That's it. No shaft coming out of the motor.
azcorolla is offline   Reply With Quote
