a/c belt idler pulley - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-26-2011, 12:42 PM   #1 (permalink)
View agmgranturismo2006's Photo Gallery
i replaced my a/c belt recently after the replacement i got a screaming noise from the a/c belt idler pulley also its getting extremely hot ( i dont have power steering) i put some wd40 on the pulley the sound dissapeared but i am worried i think this pulley has faield i need advice please?
[SIGPIC]GRAN TURISMO the real driving
simulator
agmgranturismo2006 is offline   Reply With Quote
Old 02-27-2011, 09:42 AM   #2 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
did you remove the idler pulley or just loosen it to replace the belt? Also did you install it or tighten it back correctly? It would be obvious to me that if I was hearing this after just changing the belt. I would assume I did something wrong. And if so, the bearing may be bad now after running it.
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 02-27-2011, 11:25 AM   #3 (permalink)
i removed the pulley and installed the belt i checked every thing several times its fitted correctly but i checked the pulley itself ther was slight noise coming from its bearing i think its faulty and need replacement
simulator
Old 02-27-2011, 04:50 PM   #4 (permalink)
trife96's Avatar
prolly, i'm assuming u had a reason for changing the belt. And in most cases, if a belt comes off or all of a sudden breaks, then a pulley is usually to blame
Old 02-27-2011, 09:20 PM   #5 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Yes idler IS bad!
-SP
