Corolla Newbie - Fuel mileage question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-28-2011, 02:13 PM   #1 (permalink)
Improving my ride
View hawkman71's Photo Gallery
Hi all,
I've been poking around for some time, and finally getting into some questions. It appears there is a great group of people on this forum, and the feedback and DIY threads are awesome!
I have had a 1996 DX (1.8 L) Corolla for about two years now. Bought it used for about $2k with only 90,00 miles on it! Automatic, AC etc.
My fuel mileage has gotten shaky lately. Dropping from upper 35 to around 30-32, with 28 being the lowest. I DID put a bike rack on, which dropped it by about 1-1.5mpg, but the rest of this drop is unexplained. I just recently had a check-engine light come on which coded as P0401 (EGR flow insufficient), which I've read on some forum (maybe this one) that it could very well be the VSV. I haven't checked this yet...
1. What is the best fuel mileage one could expect with a stock Corolla w/1.8L engine?
2. Is there a list of things that I can check into/work on in order to improve this?
I have some other questions, and am thinking I'll put them into separate threads over time, so as to keep the thread focused.
Thanks so much.
hawkman71 is offline   Reply With Quote
Old 02-28-2011, 03:46 PM   #2 (permalink)
View tgerhard's Photo Gallery
Hello hawkman,
I've got a '95 1.8L that consistently averages 35 mpg.
tgerhard is offline   Reply With Quote
Old 02-28-2011, 05:41 PM   #3 (permalink)
Gameroom cash: $816401
View zythr's Photo Gallery
You'll also have slightly lower mileage if winter blended fuel is used where you live.
zythr is offline   Reply With Quote
Old 02-28-2011, 10:42 PM   #4 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
the VSV is a good place to look. Especially since you got that code. The valve could very well be sticking open, or closed. When is the last time you had a tune up, oh and check tire pressure btw lol
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 03-01-2011, 08:31 AM   #5 (permalink)
Improving my ride
I DO have a slow leak in one tire. Need to get that fixed. It might explain the variability in mileage. Although I drive in the country (~60) and on the highway (75+), sometimes with a 275lb passenger..
Never a tuneup. Do my own stuff, but probably ought to get a tune-up. I'm just scared of giving a car to a guy who will do more or charge more than necessary. Perhaps this is an unjust fear.
I figured I could start with plugs (i've never checked them yet), wires, cap, rotor.
I thought I out to change tranny fluid, and maybe front transaxle (unless these are one-n-the-same).
Old 03-01-2011, 09:10 AM   #6 (permalink)
trife96's Avatar
Fix the leak, but u definitely prolly need a tune-up, and I agree, don't take it to a mechanic. Plugs, rotor, cap, all can be done pretty easily for less than a $100. Then see where you stand.
If you change your tranny fluid, the tranny and differential fluid is gonna be all in one, not seperate. But on some with the 1.6 3 speed with no overdrive, they have seperate chambers for the fluid. Not the case for you since I'm assuming you have the 1.8 with the overdrive
