Leaking strut. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-01-2011, 02:03 PM   #1 (permalink)
Improving my ride
View hawkman71's Photo Gallery
Leaking strut.
I was changing the oil this winter, when I noticed my RF wheelwell was covered in an oil. I deemed it was the strut leaking as it was coated, including the part inside the spring. I noticed small amounts leaking up in the engine compartment around the 3 bolts for the strut.
So...I was told by the guy at Advance that that part is about 100 bucks, including spring etc. I figured my old spring is fine, so I'm not sure about where to go there.
I've seen full struts/springs for ~50 on ebay...
I could use advice on:
1. Brand/quality. (Go with minimum? My budget is low, but I would like it to ride good).
2. Full kit, or just the strut. I can borrow a spring compressor if needed...
3. Replace both sides for sure, or only if problem in both?
Thanks!
hawkman71 is offline   Reply With Quote
Old 03-01-2011, 03:41 PM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
At a minimum chage BOTH struts. They should be sold in pairs! If you have a high mileage car new springs will help ride quality further. KYB are nicely priced and good quality.
-SP
Old 03-02-2011, 07:32 PM   #3 (permalink)
Improving my ride
I swear I checked the 'bounce' in the front of the car just a few months ago - back when I really noticed the thing leaking. Today I checked, and holy cow - I need both front struts replaced. I'm seeing this as a 200 dollar job if I buy from advance. Unless I buy just the strut, w/o spring. But I might need to replace the spring if it's bad right? Or are those chances low?
Old 03-03-2011, 08:39 AM   #4 (permalink)
View 96coroll's Photo Gallery
struts
Hey i just had this problem with my rear struts. I wanted to Kyb;s but they were like 160 for the strut along i believe. And i didn't wanna have to go thru the work of changing the spring. So i ended up buying it from http://www.primechoiceautoparts.ca/. I paid 84 each for complete strut and free shipping. To me in canada at least from ottawa warehouse. But i believe they have some in the states too.
Well i installed them on my car. My only issue was on one side. When i went to slide up the strut into the three holes at the top. It didn't go write away. One bolt was off by like 1mm. So i just had to pry it over and then it all went in. Tightened it and up and that was it.
Last little thing. Even though i tighten them down to spec i still sometimes get a squeek from them when driving. Know it can be annoying. I think it happens because the top plate may not be Exactly the same as the stock ones. But i'm not to concerned any more because i'm talked to a couple people who have changed there struts with not stock and they have the squeek. Once though that i could lower the strut and maybe put some greese on top plate and then reinstall. Never on to it.
Well that's my input. If i cud afford the OEM ones i wud have. Or i'm still in the hunt for a parts car. To get parts that way.
Oh and if your changing them yourself he front struts are easier to change than the rear ones.
96coroll is offline   Reply With Quote
