Cool lil geo..... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-03-2011, 10:53 PM   #1 (permalink)
View 40ronn's Photo Gallery
Cool lil geo.....
Just pickd up a 94 prizm....... it has 90k original miles on it so its something I want to keep for a while........ how hard is it to put in factory pwr locks n windows all around if I get the set up used ?
Sent from my PC36100 using AutoGuide App
40ronn is offline   Reply With Quote
Old 03-05-2011, 11:18 AM   #2 (permalink)
Can anybody help me........ I just want to knw if these things came with plug n play........
Old 03-07-2011, 10:12 AM   #3 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
I've heard they are, but, when I bought a corolla I was flipping for cash, it had a rear passenger door that was damaged. So I installed a door that was the same color, but it had manual windows and locks. So I was installing a manual door on a Corolla that already had the power windows and locks and HARNESS (manual does not come pre wired as most people have said). I was successful in swappin the window regulator quite easily. You have to drill the hole in the door for the harness to go thru since the manual doors don't come with the hole pre-drilled. But I couldn't figure out how to swap the lock, and since I was selling the car, I wasn't to concerned about it. But I was successful at installing the power window.
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 03-07-2011, 05:45 PM   #4 (permalink)
Gameroom cash: $816401
View zythr's Photo Gallery
it will be some work. It would be best to get a manual with the wiring schematic, since some wires for power accessories are installed in the roof of the car. Also, you will need a connection to the battery to run the windows/doors, which may mean cutting through the firewall. Plus, if this is not done right, there is the risk of an electrical short(s), that could cause a fire. IMO, more problems than they're worth.
zythr is offline   Reply With Quote
Old 03-07-2011, 07:43 PM   #5 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
I can say that I remember there being a couple unused connectors inside the front doors of my non power window and non power lock Prizm, if they were for windows and locks I'm not sure.
Bitter is online now   Reply With Quote
Old 03-09-2011, 10:10 AM   #6 (permalink)
Thanx a lot guys, greatly appreciated........
Old 03-09-2011, 04:24 PM   #7 (permalink)
trife96's Avatar
This may be true on a Prizm. Prizm's wiring and ECU is different from the Corolla. for some reason GM used there own wiring and connectors. I noticed it a few times when I was robbing parts off of a Prizm for my Corolla. All though location of the ECU and the engine harness was very much the same. I think the connectors for majority of the body harness was different.
Old 03-09-2011, 07:00 PM   #8 (permalink)
View mcgiiver's Photo Gallery
ECU difference
What is the differences in the ECU's? I always assumed they were exactly the same, just different bodywork between Prizm and Corolla.
mcgiiver is offline   Reply With Quote
Old 03-09-2011, 08:29 PM   #9 (permalink)
trife96's Avatar
Exactly...
^ Say for some odd reason, you needed a replacement ECU and you went to the junk yard and found a comparable Prizm by year, options, and features. You will notice the ECU is mounted in the same location, but the harness connectors are different. At least, thats what I've seen on a Prizm I was robbing shift cables and a shifter out off. The body harness connectors were different.
Old 03-10-2011, 07:57 PM   #10 (permalink)
Bitter's Avatar
might have been a different engine/trans than yours. My prizm had a denso ecm.
Old 03-10-2011, 11:16 PM   #11 (permalink)
trife96's Avatar
it was older than mine, like a 94 but still had the 4AFE with manual. Mine was a 7AFE with auto
