Engine dies when warmed up, no warm restart - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-05-2011, 11:38 PM   #1 (permalink)
View JohninVa's Photo Gallery
Hi folks, I'm stumbling through this, so any help is appreciated. My 95 Corolla starts fine cold, but after I run it up to the store, it won't restart for about a 1/2 hour or so. Did some checking and if I start it and let it idle it dies in about 5 mins or so. Been trying to get smarter by surfing for answers, but have not solved it yet. I changed plugs, wires, dist & rotor tried a new coolant temp sensor (was questioning the auto parts guy tho. The one he gave me goes in right near / under the dist. with 2 wire harness. The receipt said radiator switch?? but he double checked it and said it was correct...) Anyway, i tried it and no change, so I took it back. I've cleaned the throttle body.
* It will restart with starting fluid sprayed in, and run briefly.
* I have engine code 14
Like I said, I'm fumbling through, but seems like a fuel issue?? what/how can i test further. Any and all Help is appreciated!!
*have a fuel pressure gauge but now see that I need a special adapter !! arggghhh.
JohninVa is offline   Reply With Quote
Old 03-06-2011, 11:15 AM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
could be a bad fuel pump, since you're not getting fuel when it won't start.
Bitter is online now   Reply With Quote
Old 03-06-2011, 02:21 PM   #3 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Distributor CAP and rotor or distributor??
-SP
Old 03-07-2011, 10:44 AM   #4 (permalink)
sorry, yes dist CAP,
thanks for all the replies. I can't find the adapter for fuel pressure tester except on ebay and i gotta get the car runnin. I'll just pop the fuel line to see if it's getting any fuel at all.
I'll let you know......
Old 03-08-2011, 02:39 PM   #5 (permalink)
ok, we have fuel. No Spark!! checked 2 plugs. Could the coil be overheating or....?
Old 03-08-2011, 03:38 PM   #6 (permalink)
Andele, andele!
speedy25's Avatar
distributor.
-SP
Old 03-08-2011, 06:51 PM   #7 (permalink)
Speedy, The whole distributer?
Old 03-09-2011, 01:07 PM   #8 (permalink)
Andele, andele!
speedy25's Avatar
Sometimes it can be just the coil, but other times its something else you cant replace. Look through the distributor threads and see if it matches you.
-SP
Old 03-09-2011, 04:37 PM   #9 (permalink)
Gotcha. I got a reman dist today for 200 and put it on..... solved the problem!!!!!!
Thanks for the input.
Old 03-09-2011, 09:44 PM   #10 (permalink)
Andele, andele!
speedy25's Avatar
Its nice to get something working again without too much struggle.
Glad its done.
-SP
