Originally Posted by engineerguy3809
Thx Kiwi,
You 'da Corolla answer man.
Should instrument lamps be incandescent or are they LED?
Similar question, is the instrument cluster hard to pull in order to replace the lamp (assuming it is simply burned out)?
Hope neither you, nor any family was injured or suffered property damage in the recent NZ earthquakes.
No problem
. Feel free to click the
button below my post if you like
The instrument cluster lights are incandescent. A lot of people upgrade them to LEDs as the light output is a lot greater and they last virtually forever. Removing the instrument cluster is easy. You just have to remove the two screws at the top of the black plastic surround and then pull each side of the bottom of the surround to disengage the clips. Manoeuvre the surround out and away from where you're working (this can take a bit of time unless you've got an adjustable steering column) and then you'll see four screws, one on each bottom corner and two up the top.
Remove the four screws and then you'll be able to get the instrument cluster out. The difficult part is unplugging the wiring connectors on the back. Each connector will have a 'button' up the top which disengages the connector from the back of the cluster, so just feel around until you find them. Installation is the reverse of removal
Fortunately my family and I weren't injured in the recent earthquake as we all live in Auckland which is near the top of the North Island, whereas the earthquake happened in Christchurch which is near the top of the South Island. Thanks
