It's been a while since I posted about my Prizm. The last time I was here I was rebuilding the bottom end after the timing belt tensioner failed. Everything has been going good the past 14k miles. I'm now at 260k+. The cylinder head still leaks oil into the chambers I believe because the knock has come back to an extent. I have to use 93 octane again. It burns off oil leaking past the guide seals until it heats up & expands. It doesn't do it on warmer days either. The oil leak is making me burn oil AND knocking. I deal with it because I can't afford head work.
Anyway the only real problem I'm having now is what I believe to be the fuel pump. The past couple of days the car has been slow to crank but always started. Today it died as I was pulling out of my apartments for work. I checked the battery and it had 12.4V. I put another battery in from my Isuzu that read 12.2V and it still didn't start. I know the battery is good because it cranks up my Impulse no problem.
The ignition module is good I'm assuming because I measured battery voltage between the +/- coil terminals. Continuity from coil + to ground was ~0.8 ohms. Besides all that... I pulled #1 plug wire and it sparks during cranking when grounded.
The pump doesn't prime @KEY-ON. I noticed there was no fuel pump fuse/relay but just the EFI fuse/relay. The relay clicks @KEY-ON and the fuse isn't blown. I'll backprobe the pump wiring to see if I get anything. I'm thinking the pump started going out and pulled a load on the current which was causing my slow cranking and now the pump has finally died out. The car spins over fine.
tl;dr
Fuel pump won't prime. Are there any other things I'm missing on this car? This pump has four wires in the connector but the Chilton's online diagram only shows two. Otherwise I have to assume it is just a bad pump.
