How do I get a Tach for my Corolla DX? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2011, 06:45 PM   #1 (permalink)
View phillyd215's Photo Gallery
USA How do I get a Tach for my Corolla DX?
Hello Everyone, I was wondering how to go about getting a Tach in my 1995 Corolla DX. I noticed the LE was the only one that came standard with a tach.
Thanks
phillyd215 is offline   Reply With Quote
Old 03-15-2011, 07:03 PM   #2 (permalink)
Turk
View blumonster's Photo Gallery
You can go to ebay or local salvage yards to get a full instrument cluster. Take your coolant or fuel gauge off of your own and put the tachometer from the new instrument cluster in its place. I did it like this.
I had never done anything like this before, so it is easy. But be careful not to break cluster's plastic fasteners.
blumonster is offline   Reply With Quote
The Following User Says Thank You to blumonster For This Useful Post:
phillyd215 (03-15-2011)
Old 03-15-2011, 07:57 PM   #3 (permalink)
So the instrument cluster was plug and play for you? Also Can I reset the Miles on the new speed gauge or can put the old speed gauge in the new ones place on the instrument cluster?
Thank you for you reply.
Old 03-15-2011, 08:03 PM   #4 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 03-15-2011, 08:35 PM   #5 (permalink)
ohh I see, the dealer gives you and special sticker for odometers changes and that comment really helped I know more about the psysics of Flight than the instrument cluster, so please give me a break
Old 03-15-2011, 09:38 PM   #6 (permalink)
trife96's Avatar
sorry bro, but this is asked a lot. The odo can be swapped by itself. No need to swap gages fuel or coolant temp gages...
The picture shows the two different clusters...Not a before and after
Old 03-15-2011, 09:54 PM   #7 (permalink)
Sorry for the post over kill, I couldn't find the answer I was looking for. I wanted to make sure there wasn't any special parts (besides the full panel) that I needed to buy. I Know thats not a before and after (just wanted to high light what I was talking about) I am going to look on ebay and the junk yard for the full panel.
Thanks for the reply
Old 03-15-2011, 10:43 PM   #8 (permalink)
The Great One!
View jelly53's Photo Gallery
so i'm assuming you cant change the milage... you just have to go with whatever the tach comes with.
97 Corolla CE 5speed
03 Honda s2000
09 Ninja 250r
jelly53 is offline   Reply With Quote
Old 03-15-2011, 11:29 PM   #9 (permalink)
I read here that it was done in a 99
http://www.cardomain.com/ride/806193...corolla/page-4
But I read here it couldn't be done in a 95, and that you need a placard to show the difference between the old(actual) odo millage and the new one.
http://www.cardomain.com/ride/605140...corolla/page-3
according to trife96 "The odo can be swapped by itself."
Old 03-16-2011, 11:58 AM   #10 (permalink)
Turk
You can just take your speedometer and plug it into the new cluster.
It is just plugging it.Nothing to change/modify.
I did it on my 1994 Geo Prizm.
My instrument cluster was exactly like the one in the first picture. (Except that the narrow bottom part is the top part, top part is the bottom on Geo Prizm, just the frame of the cluster, not the gauges.)
I took the speedometer and put it in the new cluster. My miles were lower, I did not want to use the high miles odometer.
No need to reset miles on the odometer.
Old 03-16-2011, 11:59 AM   #11 (permalink)
trife96's Avatar
^ correct, I've swapped two already with success. Basically once you remove the cluster, you will notice the cluster splits in two halves. Also you may or may not have to unclip the clear lens depending. Unclip the two halves...and be careful, those plastic tabs can become brittle and break easily. Then you will see the odo is held in by three or four screws in the back....
But on the flip side, the old cluster WITHOUT the tach, also has two screws behind the mph gage. you will have to pull the needle off and remove those two little screws, then proceed to split the cluster and remove the same 3 or 4 screws in the back. The tach cluster will not have the two screws in the front so DON'T pull the needle off or it will be a PITA to get it back right (I made that mistake). But yes, it's not to hard
edit: actually, I think you have to pull the needle off regardless. Which means you will have to spend some time recalibrating it. I did this with the help of a friend and his car by leaving the clear lens off and pulling it on and off until it was right
The Following User Says Thank You to trife96 For This Useful Post:
phillyd215 (03-16-2011)
Old 03-16-2011, 12:15 PM   #12 (permalink)
Turk
trife96, I just saw your cardomain page. How much did replacing the engine and transmission cost you? Looks nice.It seems you did the work yourself.
Old 03-16-2011, 12:23 PM   #13 (permalink)
trife96's Avatar
^thanks man...yea I'm a DIY'er, engine with tranny was around $1300. Been so long I don't remober exactly. I plan to be done with it by the end of April
Old 03-16-2011, 12:36 PM   #14 (permalink)
I just took out the cluster. I see what you guys are talking about. That just what I need. Looks the the needle will be the biggest PITA. I guessing you cant just pull it back to zero or something Ill see when I get there. Thank you for the info. I see some on the internet for around 70bucks I'll order next week (birthday money!!)
Old 03-16-2011, 12:41 PM   #15 (permalink)
Turk
I did not have to mess with the needle at all.It did not move.It stayed where it was. Maybe Corolla is different?
You can get it even cheaper.Keep looking at ebay listings, try different search words/ key words. Sometimes even a typo can hide a listing from people, if you find it you are lucky.
Tags
1995 corolla dx tach
