Labor question - timing belt + valve cover gaskets + clutch job - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-17-2011, 04:24 PM   #1 (permalink)
View bigd480's Photo Gallery
gen 7 Labor question - timing belt + valve cover gaskets + clutch job
I need valve cover gaskets done and am overdue for a timing belt change so I figured I'd get both done at once since they would have to remove the VC anyway to do the timing belt.
Any ballpark on how many hours a shop should charge to do them together?
Anything else to do there other than belt/tensioner, water pump/gasket/belt, bypass hose, crank/cam seals?
I've seen people recommend thermostat and upper/lower hoses but it seems like you can do that whenever? Or does the water pump replacement require a cooling system burp so it's better to do those together?
What I'm also curious about is if there is any advantage to get my clutch replaced at same time? I'm at 150k on stock clutch, and just got a new Sachs clutch kit, flywheel and RMS for $60 on Craigslist. Doesn't seem like there would be any common labor but just thought I'd ask.
Thanks!
bigd480 is offline   Reply With Quote
Old 06-09-2011, 10:18 AM   #2 (permalink)
bump
Old 06-09-2011, 03:33 PM   #3 (permalink)
View 03keen's Photo Gallery
at least do the thermostat, the fluid will be out and its a good time to do it when you change the water pump/coolant. if your hoses are still flexible just keep them. if they are brittle change them. as for the rest i am not that toyota saavy. yet. but AFIK that sounds about right. and should be around 4-6 hrs of shop time for all.
03keen is offline   Reply With Quote
