95 corolla late shifting???? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-19-2011, 04:20 PM   #1 (permalink)
View cooperdeville's Photo Gallery
Hey guys, i have a 95 corolla (auto trans) and recently done the water pump and timing belt. All went well there, but since i done that whenever i drive it it shifts extremely late when at wot, and seems to be using much more gas. It seems that i have disturbed something when i removed the starter, the throttle linkage seems to be alright, could this be a sensor problem or computer problem, thanks to all in advance
cooperdeville is offline   Reply With Quote
Old 03-19-2011, 09:07 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
at full throttle it should shift just before 6000 RPM, around 5500-5800 RPM.
Bitter is online now   Reply With Quote
Old 03-20-2011, 01:51 PM   #3 (permalink)
today after i messed with the adjustments and checked the tps and vss sensor (unable to test vss) i went for a drive around the block and it was fine but before i got it home it went back to the way it was before not shifting at wot, i had left the key on all night and had to jump start the car also. do yall think this is a sensor, ecm problem or the tv cable possible hanging up??
Old 03-20-2011, 07:50 PM   #4 (permalink)
Bitter's Avatar
what gear does it stay stuck in? does it just bounce off the rev limiter?
Old 03-20-2011, 10:07 PM   #5 (permalink)
not sure it is a particular gear, what happens is when i floor it, at any speed, it will down shift and rev up like normal but it will not up shift till i let of the accelerator a bit, most of the time when i rev it i let off for fear of it tearing up the motor, i don't have a tach so i dont know what rpms it gets to but its over revving bad.
Old 03-20-2011, 10:19 PM   #6 (permalink)
also i arced the starter to the car when doing all the original work, this is the reason i have been checking all the electrical. This was my first timing belt and has been quite a pain. also, i had messed with the tv cable all day and im pretty sure that this is not the problem, what do yall think? Thanks for all your continued replies.
Old 03-21-2011, 07:13 AM   #7 (permalink)
Bitter's Avatar
it could be the TV cable. it should be pretty slack, tight makes it shift later, too slack makes it shift too soon. It should only be tight when the throttle is wide open.
Old 03-21-2011, 08:58 AM   #8 (permalink)
also there is no check engine light on, could a vss, tps crankshaft postion sensor be bad with no light on?
Old 03-21-2011, 07:37 PM   #9 (permalink)
Bitter's Avatar
Yes
Old 03-22-2011, 11:26 AM   #10 (permalink)
replaced ecm, didnt help, i will take it back to the junk yard and get a vss and tps and after that i think ill give and take it in i seem to have hit a brick wall
Old 03-25-2011, 09:06 PM   #11 (permalink)
replaced vss and tps, no help, i toyed with it and it only does it when its warm once it reaches operating temp it starts messing up
