Originally Posted by CJRocker
Most common issue that lead to fuel leaks is the filler neck and fuel lines. If the fuel lines are rusty get the brake lines done at the same time. Look at new belts (AC, power steering, alternator/water pump), plug wires/dist. cap/rotor/plugs. For plugs I used Denso Platinum Twin-tip and they are really nice plugs. I've had good luck with Seafoam as have others, and despite the low miles the age suggests it could use it.
Thanks I'll check the lines out too didn't think about those. I noticed it drips right around the cap area though so I'm guessing it's the neck.
I noticed a random hose today that was only connected to the coolant lid so I'll snap a picture of that because I still haven't figured out where it goes. My only guess so far is the thermostat(and that could be the issue) but I have to take off the distributor to get a better look cause I couldn't see it at the moment.
I'll definitely look into the plugs you suggested as well. I didn't grab the seafoam today but it did sound a bit better after the oil change. I noticed whoever did one last had put on the wrong oil filter on it ha. I don't know how that affected/effects it but I notice a little difference now.
