Adding Cluster W/Tach Need Help!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-23-2011, 07:41 PM   #1 (permalink)
View EstebanGM's Photo Gallery
Hey,
Am new to the forums I have a 1997 Toyota Corolla 1.6L Base Model 5 M/T. And it does not have a tachometer so I picked up a 1993 Corolla Cluster with tachometer and I have plugged it in but have one small problem I plugged in the three plugs but am not getting a reading on the RPM. Everything else is working fine though.
Thanks for the help in advanced.
EstebanGM is offline   Reply With Quote
Old 03-23-2011, 09:40 PM   #2 (permalink)
View 1steve's Photo Gallery
You will need to get a wiring diagram and find out which wire has tach signal to cluster and see if its missing because it didn't have a tach or if its there and not receiving RPM signal.
1steve is offline   Reply With Quote
Old 03-25-2011, 07:40 PM   #3 (permalink)
Yea, thats what I was thinking but I kept reading that it was plug-n-play so I was a bit confused. But nevertheless I took the rpm signal wire from the diagnosis plug up in the front engine bay and brought it through the firewall to the cluster wiring harness.
Old 03-26-2011, 12:18 AM   #4 (permalink)
Matt94MR2's Avatar
Gameroom cash: $247750
View Matt94MR2's Photo Gallery
Weird, I have a '96 base model, 1.6L, 5-speed and mine was plug and play with the tachometer cluster. It sounds like you got yours working though, I am curious what the difference is...
1994 Toyota MR2 Turbo, Gen3 3S-GTE, 278 rwhp, 12.8 @ 106 mph in the 1/4 mile
1996 Toyota Corolla, 4A-FE, 5-speed
Matt94MR2 is online now   Reply With Quote
Old 03-26-2011, 02:37 AM   #5 (permalink)
bjmtz's Avatar
View bjmtz's Photo Gallery
is it country of manufacture?
Canada vs. Japan vs. NUMMI
Passion is Fashion. Get yours.
1994 Super Red Corolla 88000mi 7afe AT
Bumps!
bjmtz is offline   Reply With Quote
