digital clock installation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2011, 07:14 AM   #1 (permalink)
e10097's Avatar
Gameroom cash: $123150
View e10097's Photo Gallery
Australia digital clock installation
Hi guys
I currently have a base model corolla and i was wondering if it were possible to install a digital clock similar to what was available in the more expensive models into the dashboard ?
Its the clock that sits next to the centre air vent that has three buttons and a green LED display which was installed standard on more upmarket models but not mine.
Thanks
CAR SPECIFICATIONS:
- Toyota Corolla (E100) CSi Sedan
- Manufactured 1997
- Distance covered 150,000km
- Engine 1.6L coupled with 5 speed manual (no modifications)
e10097 is offline   Reply With Quote
Old 03-27-2011, 03:14 PM   #2 (permalink)
Token Aussie
Hiro Protagonist's Avatar
Gameroom cash: $179000
View Hiro Protagonist's Photo Gallery
Originally Posted by e10097 View Post
Hi guys
Sure is possible, 90% sure that the only Australian-delivered models which had those clocks are the imported Sprinter 5-door liftbacks so you might have to do a bit of hunting around for them (or ask nicely from an overseas member here). As fas as the actual install goes, it is as simple as removing the fascia panel - just pull off the HVAC knobs and gently pull the panel towards you, then unplug the wiring for the rear demister and hazard lights, and the whole thing should come out. There is one screw holding the fake air vent in, so you just unscrew it and screw the clock into its place. The hardest bit is splicing into your headunit wiring to get +12v BATT, +12V IGG and GND, but if you're any good with a multimeter and a pair of crimpers this seriously takes 10 minutes.
Charlene - 1997 AE102 sedan: FXGT of awesome
Billie - 1981 KE55 sedan: GOOOONNNE
Rosie - 1986 AE82 Twincam Seca: Converted into garage space
Charlie - 1988 ST62 liftback: Moored in the garage
Lexi - 1995 JZZ30 GTTL: Hunting n00bs in Skylines and SS Commodores
Hiro Protagonist is offline   Reply With Quote
The Following User Says Thank You to Hiro Protagonist For This Useful Post:
e10097 (03-28-2011)
Old 03-27-2011, 11:09 PM   #3 (permalink)
Life's better in a Toyota
Callum3's Avatar
View Callum3's Photo Gallery
Not 100% sure about Australian models but when I did this install on mine (Canadian model) the plug was already there (tucked away but there) it was just plug and play, no cutting or splicing wires
03 4runner - 2UZFE - Beauty and a beast!
95 Corolla - 7AFE - 405,000kms running strong
76 Land Cruiser - FJ40 - Needs restoring
Callum3 is offline   Reply With Quote
The Following User Says Thank You to Callum3 For This Useful Post:
e10097 (03-28-2011)
Old 03-28-2011, 01:27 AM   #4 (permalink)
e10097's Avatar
Thanks guys for the information it really helped - i will pick one up from the wreckers sometime soon
Old 03-28-2011, 01:32 AM   #5 (permalink)
e10097's Avatar
Australia
In australia we had the base model CSi, the mid range CSX and the range toping Conquest. Fortunately my car was built in 1997 by this stage all models had aircondtioing as standard - which you KIND of NEED in Australia.
Old 03-28-2011, 03:07 AM   #6 (permalink)
Token Aussie
Actually the Aus model range is a bit of a mixed bag - the Conquest and CSX seemed to vary as to which was higher spec depending on whether it was before or after the facelift, or whether the CSX was the 1.6 or the 1.8 (Conquest was 1.8 only). Also, neither were the range topping model - that was either the luxury Ultima sedan (ultra rare, I've only seen 2) or sporty RV Seca (fairly common, I see them probably daily)
I've got the sales brochure in front of me and it is a little confusing to say the least.
Old 03-28-2011, 03:28 AM   #7 (permalink)
e10097's Avatar
Australia
Yeah I know it is a little crazy I have the Gregory's Automotive-Service and Repair Manual for the E100 AUS Spec and it mentions the CSi, CSX, Ultima, Conquest, RV, Seca IN THAT ORDER so it is really confusing
I think the Ultima was the most expensive of the day in Australia I have only seen a few myself - i think price had an influence though because a brand new 2011 Toyota Corolla Ultima is priced at AUS$30,000 or higher I believe that's $10,000 more than the base model (i've only seen one). For that money one is better off just buying a brand new mid-range Volkswagon Golf, i like Corollas but not enough to spend 30,000!
1997 AE102 Toyota Corolla 1.6L/5-speed manual
Manufactured in Victoria, Australia
170,000km travelled
Old school JDM luxury
Old 11-26-2011, 05:31 AM   #8 (permalink)
Nick
Gameroom cash: $155900
View TheNightWolf's Photo Gallery
Sorry to bump, but the clock was only available in the higher end models?
Mines a Base with the clock, mines a US model though, if that changes anything.
-1994 Toyota Corolla-Ksport Coilovers, custom exhaust, Weapon R intake with Ram Air Kit
TheNightWolf is online now   Reply With Quote
Old 11-26-2011, 05:03 PM   #9 (permalink)
96 Toyota Corolla
kickfli12's Avatar
Gameroom cash: $133700
View kickfli12's Photo Gallery
im in the same boat as callum3. mine was plug and play and the plug was tucked away behind the dash. i have an extra clock in my car but it has a very small crack in the bottom of it but it still works. chances are good that you can get it at a local junkyard than it would cost you in shipping.
i have a factory spoiler for sale.
http://www.toyotanation.com/forum/66...ake-light.html
kickfli12 is offline   Reply With Quote
Old 11-26-2011, 11:19 PM   #10 (permalink)
Token Aussie
No Australian-made models had it, which would probably be why there is no plug in the loom either.
Old 11-27-2011, 07:15 PM   #11 (permalink)
e10097's Avatar
Australia
Hey guys,
good to see this thread alive again My car has changed greatly since then.
Here's a pic of my clock. I had to plug it into the back of the radio. Easy job. Honest.
Sorry for poor quality pic.
170,000km travelled
Old 11-28-2011, 12:14 PM   #12 (permalink)
View 96coroll's Photo Gallery
I've got one. I'd give it to you for 5bucks. It would be coming from toronto. PM me if your interested
96coroll is offline   Reply With Quote
