1993-1997 corolla climate control light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-28-2011, 02:40 AM   #1 (permalink)
View 1994 Corolla Kid's Photo Gallery
Does anybody know how to take out the climate control and change the bulbs my bulbs do not work have new ones but I can't figure out how to take the climate control out mainly I want to know where the bulb location is on the climate control and how to take the unit out please help thank you
1994 Corolla Kid is offline   Reply With Quote
Old 03-30-2011, 07:28 PM   #2 (permalink)
View marsala4's Photo Gallery
Remove the knobs from the controls, remove the bezel by using a trim tool or small screw driver, the bezel is snapped in with four clips, two about and inch or so below the top corners and two above the bottom, (all four are located on the sides). they will pop out with a little prying. Un plug the electrical connections on the right hand side and possibly on the bottom. Once the bezel is out of the way, you will see a clear plastic bar that sits behind the temp controls. This clear bar is the light bar, gently pry it out from one end and remove it. Be careful not to break it. Once the light bar is removed you will see the bulb, It really is not difficult, just be carefull when prying out the bezel and light bar. Put it all back together, (snap it all in place) and your done. Hope this helps.
marsala4 is offline   Reply With Quote
