Originally Posted by Kiwi-Corolla
Patience is a virtue  . The one nearest the distributor is the thermoswitch and the other one is the coolant temperature sensor.
Yeah I should have waited but I got inpatient lol but thanks!
I have a problem with my fan turning on so I figured I'll check to see if it works. So I manually jumped it to the battery and it works. So I'm trying to figure out if its the sensor or the relay.
*How do you jump the fan switch so that it automatically turns on? Usually on my civic I would just take a paper clip, fold it in half and stick it into the two pins and turn the car on. But for the toyota it looks like theres only 1 pin for the fan connector.
btw the fan does turn on only when I turn on the a/c. Is that weird? It turns on and then turns off then like 30 secs later it turns back on.
Please help me! Thanks in advance
