1995 Corolla does not start when engine is warm. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2011, 11:41 AM   #1 (permalink)
View greg_jones's Photo Gallery
It always starts in the morning and after work(in the evening) but if I shut it off then restart it while the engine is still warm, it stalls. Usually I have to wait at least 4-5 hours to start it back up again so that it will run fine. If I try to start it back up soon after I shut the engine off, it dies just when I shift to drive/reverse/neutral. Basically the engine needs to cool down for it to start(and drive). It has no problem starting and driving in the morning while the engine is cold. No check-engine light on. Replaced spark plugs few months ago. Also one more problem - when going around 50-55mph, it feels like the engine is trying to stall. I shift it to N for few seconds then its usually fine again.
1995 Corolla base 1.6L AT.
Any help?
greg_jones is offline   Reply With Quote
Old 04-04-2011, 06:31 PM   #2 (permalink)
View marsala4's Photo Gallery
My sons car was experiencing something similar to this going down the highway, I discovered that part of the cat had broken loose and fell down into the exhaust hole nearly blocking the pipe. I disconnected the pipe at the bottom of the cat, removed the chunk, put a new gasket in solved the loss of power going down the highway problem. He has the same engine. Hope I've help at least part of your problem.
marsala4 is offline   Reply With Quote
