No fire at the plugs, why? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2011, 10:38 PM   #1 (permalink)
View marsala4's Photo Gallery
94 Prizm, 130k miles, 1.6L, three speed auto,, new ngk plugs, cap, rotor, plug wires. I am not getting fire to the plugs, replaced the coil with one from another distrbutor, still not fire.
What could be causing the no fire issue, all suggestions welcome.
marsala4 is offline   Reply With Quote
Old 04-02-2011, 08:30 AM   #2 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
I have had the ignitor fail. Its inside the distributor, id swap another distributor and see what happens. Usually people don't have success replacing individual components in these distros and end up buying a used assembly.
Any traces of oil inside the old cap?
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
The Following User Says Thank You to 1jzdreamer For This Useful Post:
marsala4 (04-04-2011)
Old 04-02-2011, 09:22 PM   #3 (permalink)
I believe ther was a little oil on the bottom side of the cap. I just put a new valve cover gasket w/ plug tube seals as well. Would this oil be coming past the O ring on the dist.
also, I found a used dist for 85 bucks, Advance auto parts sells the igniter for more than you can buy a new dist. new dist = 188.00
Old 04-03-2011, 08:47 AM   #4 (permalink)
tacosteelersman's Avatar
Gameroom cash: $170177
View tacosteelersman's Photo Gallery
Get an exploded view of your distributor, thats what I did for my 95 Tacoma, low and behold the dizzy has an oldfashioned condensor in it. I changed the condensor and my Tacoma came back to life.
95.5 Tacoma 2.7 300,000
91 Corolla 1.6 180,000
96 Avalon 3.0 190,000
95 Ford Aspire 1.3 125,000
tacosteelersman is offline   Reply With Quote
The Following User Says Thank You to tacosteelersman For This Useful Post:
Old 04-03-2011, 12:30 PM   #5 (permalink)
Saloon Fanatic
The oil comes through the brass bushing inside, the o-ring is the outer seal to the head, then the brass bushing is the seal around the shaft into the dizzy. If its seeping, id swap it out as you risk killing new components you put in with it. Thats how 2 of mine have failed.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
Old 04-03-2011, 07:47 PM   #6 (permalink)
Thanks guys, I will try both and see what happens. Will post results tomorrow. I have an old dist, I will try the condenser and I also own a 94 corolla but it has a 1.8L. I will check to see if they are the same and try swaping if they are.
Old 04-04-2011, 06:21 PM   #7 (permalink)
Update, I did not try the condensor, I found a used reman at a junk yard and replaced the dist. Problem solved. Thanks for your input.
Old 04-04-2011, 07:07 PM   #8 (permalink)
DOHC VTEC
View Nusdogg's Photo Gallery
Glad you got it fixed!
I was just gonna say check the igniter or swapped for a known running distributor.
204whp/157wtq
Nusdogg is offline   Reply With Quote
