Originally Posted by SupaRitz
so dont get wide tires and im good ?
As long as you don't get tyres that are too tall or too wide then you shouldn't have any problems. However, there are many variables involved when it comes to the wheels. Don't go for anything with an offset lower than 35p and don't go any wider than 7.5 inches. Also, if the 16" wheels were factory wheels off another car, make sure the centre bore size is compatible with your Corolla. If they're aftermarket wheels then the centre bore size will be quite large so you won't have to worry. If you stick to those rules then you shouldn't have any trouble
