power steering fluid flush?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-05-2011, 04:04 PM   #1 (permalink)
The Great One!
View jelly53's Photo Gallery
hey guys, today i was looking over the engine bay and noticed the power steering resivior. the car is 14 yrs old with 167000 miles and i believe the power steering fluid has never been changed or flushed. so have you guys done this? if so, how is it done? thanks
97 Corolla CE 5speed
03 Honda s2000
09 Ninja 250r
jelly53 is offline   Reply With Quote
Old 04-05-2011, 07:59 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
Yes, change it. remove the bottle, clean it out with brake cleaner, get a friend...
install the bottle, fill it with fresh fluid but leave the return line off and shove it in an empty waste bottle. Pull the efi fuse and have your friend crank the engine for a few seconds, refill the fluid bottle, empty the waste bottle, repeat until the fluid runs clear. Do it a few more times with the steering wheel turned all the way to one side and then the other. Put it all back together and check for leaks.
You can use Dexron trans fluid.
Bitter is online now   Reply With Quote
Old 04-06-2011, 09:44 AM   #3 (permalink)
View mvftw's Photo Gallery
...or get a turkey baster and suck out the fluid and fill, do it every 3-6 months and you will have fresh fluid (4 changes should be fine)..do the same with your brake fuild..but get a new baster...
mvftw is offline   Reply With Quote
