1994 corolla died at while parked won't start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-10-2011, 08:32 AM   #1 (permalink)
View upnorthman's Photo Gallery
Good morning,
I am trying to avoid the towing bill. It was parked at idle and just quit. No spark. I have been told that if I pull the distributor that the igniter is there and is probably dead but from what I have read on this forum it could be a number of things. It cranks over fine. Any suggestions for the novice? Thanks!
upnorthman is offline   Reply With Quote
Old 04-10-2011, 09:55 AM   #2 (permalink)
tacosteelersman's Avatar
Gameroom cash: $170177
View tacosteelersman's Photo Gallery
On my 95 Tacoma the distributor has a condensor in it, the condensor caused my no spark condition. 8 dollars later and SEVERAL tests including, crank position sensor, coil, replaced ignitor with a known good one, and checking grounds and fuses, I was rolling again.
95.5 Tacoma 2.7 300,000
91 Corolla 1.6 180,000
96 Avalon 3.0 190,000
95 Ford Aspire 1.3 125,000
tacosteelersman is offline   Reply With Quote
Old 04-10-2011, 10:27 AM   #3 (permalink)
Why yes a condenser does sound much cheaper! Thanks for the reply, I'm going to run some tests and I will let you know.
Old 04-10-2011, 06:42 PM   #4 (permalink)
kevdude's Avatar
View kevdude's Photo Gallery
Check that AM2 fuse if you got one! I sure learned some lessons this past week....
97 Avalon XL, 198,000 miles and still going!
06 Solara SLE convertible
kevdude is offline   Reply With Quote
Old 04-23-2011, 06:24 AM   #5 (permalink)
AM2 Fuse! Who would have thought it could have been so easy? I guess the original fuse was old. I can not figure why else it would just pop.....
Thanks for the comments!
Old 04-23-2011, 07:17 AM   #6 (permalink)
kevdude's Avatar
Well, in my case the distributor was causing the fuse to blow. It took a whole week of troubleshooting to figure it out, but when I put the old distributor back in it would blow the fuse immediately. New distributor, new fuse, back on the road! Glad to have helped...
