Basic electrical/wiring help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2011, 12:01 AM   #1 (permalink)
e10097's Avatar
Gameroom cash: $123150
View e10097's Photo Gallery
Question Basic electrical/wiring help
Hi Guys
After weeks of searching I have finally come across a OEM E100 digital clock for my car. It is the clock that is located in the center part of the dashboard, but unfortunately my car doesn't come with a pre-existing plug for it from what i can see - the clock sits directly above the hazard light switch by the way next to the vent.
So I was wandering if anybody could give some advice towards connecting this clock to my Corolla sedan. The clock itself was taken from a Corona model of the same generation i believe. It fits into the panel no problem
If it helps there are four wires coming out of the back of the clock :
1) white with black pinstripe {possibly ground wire}
2) green
3) blue with yellow pinstripe
4) grey
I have basic experience with electrical installations, i can connect a light to a battery but thats about it
Thanks , jake
1997 AE102 Toyota Corolla 1.6L/5-speed manual
Manufactured in Victoria, Australia
170,000km travelled
Old school JDM luxury
e10097 is offline   Reply With Quote
Old 04-14-2011, 01:39 PM   #2 (permalink)
View gomes512's Photo Gallery
Been a while since I've seen the diagram. I think the Hayne's manual has the pinouts.
Your blue yellow should be the positive. Last I was messing around with the dome light I remember that it shared the same 15A fuse. The gray should be the accesorry relay so that should be the same as what the cig. lighter is on. Your white black is ground. So that leaves green which means it goes to the illuminator control. Probably double check that.
Sorry I can't be of more help, but just check the Hayne's manual for the diagram.
gomes512 is offline   Reply With Quote
