DIY Trunk Light Switch Replacement Corolla 93 - 97 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-15-2011, 11:40 AM   #1 (permalink)
CorollaCarClub.proboards.
RinconRolla98's Avatar
View RinconRolla98's Photo Gallery
Exclamation DIY Trunk Light Switch Replacement Corolla 93 - 97
This is a DIY on how to replace or add a trunk light switch for a 93 - 97 Corolla .
The Switch is connected to the trunk hook . You do not have to remove the hook just the switch .
First you remove the plastic piece and the carpet that covers up the area .
Then with a angle phillips screw driver you unscrew the switch from the hook .
This is a example on how you would do it .
Then you remove the plug from the old switch then you clip on the new switch to the plug
Then you put every thing back together and test out your trunk light .
More DIY Here http://rinconrolla98.blogspot.com & Here http://corollacarclub.proboards.com/index.cgi?board=diy
RinconRolla98 is offline   Reply With Quote
Old 05-12-2012, 09:14 AM   #2 (permalink)
Gameroom cash: $127900
View Bstylz's Photo Gallery
how do i install a trunk light to my corolla?
it didnt come with a light
Bstylz is offline   Reply With Quote
Old 05-12-2012, 01:31 PM   #3 (permalink)
TIEyota fighter ace
Piloter's Avatar
Gameroom cash: $142700
View Piloter's Photo Gallery
Can you please also post a photo of where the light itself is (and what kind of bulb it takes)?
WIP AE102.
Piloter is offline   Reply With Quote
Old 05-12-2012, 01:56 PM   #4 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
it takes a 194 wedge base
it's located in the middle of the rear deck in a small gray plastic cage.
Bitter is online now   Reply With Quote
Old 05-12-2012, 05:58 PM   #5 (permalink)
96 Toyota Corolla
kickfli12's Avatar
Gameroom cash: $133700
View kickfli12's Photo Gallery
here is the trunk light diy
DIY Trunk Light Install
i have a factory spoiler for sale.
http://www.toyotanation.com/forum/66...ake-light.html
kickfli12 is offline   Reply With Quote
Old 05-12-2012, 11:55 PM   #6 (permalink)
TIEyota fighter ace
Piloter's Avatar
For those of you who don't think your trunk light works, jiggle the switch, it can get stuck in a position where the light won't come on.
Fun fact, if it's stuck in that position and you have the stock VIP RS-3000 (or whatever) car alarm, you can open your trunk when the alarm's armed and it won't trigger it.
WIP AE102.
