Oil pan change corolla 96 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-16-2011, 11:04 AM   #1 (permalink)
View QTDaniel's Photo Gallery
UK Oil pan change corolla 96
Hi,
I need to change the oil pan on my Toyota Corolla 1.3 1996 due to small hole. Please can anyone help in telling my how to do it?
Thanks
Daniel
QTDaniel is offline   Reply With Quote
Old 04-17-2011, 09:00 AM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
remove the old one and install the new one.
NOT hard job! You may need to use a knife to slice away the old gasket/silicone before you can remove the old pan.
Use gray silicone SPARINGLY!! A 1/8" bead is more than enough. Make sure the new pan is FLAT. Flanges can be warped or bent. I use the table of my table saw to check flatness.
-SP
Old 04-17-2011, 10:27 AM   #3 (permalink)
Do i need to remove the exhaust or any cross member or sub frame?
Old 04-17-2011, 09:26 PM   #4 (permalink)
Andele, andele!
speedy25's Avatar
I didnt when I did mine.
-SP
Old 04-19-2011, 12:06 AM   #5 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
Removing the brace is a ton of work in itself as 2 engine mounts are attached to it. So easier just using a small ratchet.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
Old 04-21-2011, 04:24 AM   #6 (permalink)
View slippy40's Photo Gallery
if you have the 1.3i 4efe engine this job is a potential pig as you have to drop the subframe, disconnect exhaust downpipe(bolts may snap). There is v.little room for manoeuvre.best done on a ramp.try to fix the hole and explore other avenues before starting.good luck
slippy40 is offline   Reply With Quote
Tags
oil pan removal, sump
