Removing Harmonic Balancer - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-17-2011, 01:37 PM   #1 (permalink)
View nbudusmith's Photo Gallery
I'm replacing the broken timing belt on our 97 Corolla. How do I keep the crankshaft from spinning when I try to remove the center bolt from the harmonic balancer? I tried a strap wrench, but I can't hold it tight enough to keep the balancer from spinning. Plus I'm afraid I may break the plastic timing mark tab off of the belt cover with the strap wrench.
Also, the bolts on my harmonic balancer puller do not fit the balancer on this engine. Anyone know the thread size for the puller holes on the balancer? Do I need a metric puller (or at least metric bolts)? I bought this puller many years ago when all my cars were non-metric.
Thanks for any info.
nbudusmith is offline   Reply With Quote
Old 04-17-2011, 09:29 PM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Best bet for bolt removal is go to someone with the biggest meanest air gun you can find. Puller is not needed. those are for American cars with timing CHAINS.
-SP
Old 04-18-2011, 06:54 AM   #3 (permalink)
View MrGiggles's Photo Gallery
Ingersoll-Rand makes one hell of an impact. At school we have a 3/8 IR that is 2x more powerful than my 1/2 drive.
1994 Corolla
Base/1.6 5spd
MrGiggles is offline   Reply With Quote
Old 04-18-2011, 01:20 PM   #4 (permalink)
correction: I hate Isuzus
InfInIty13X's Avatar
View InfInIty13X's Photo Gallery
1: Place your socket/ratchet on the bolt ready to loosen it.
2: Place a lead pipe breaker bar on the ratchet so that it rests on the ground.
3: Bump the starter.
4: Profit
'96 Geo Prizm base 280k+ miles
'91 Isuzu Impulse RS 130k+ miles (parked with bhg)
InfInIty13X is offline   Reply With Quote
Old 04-18-2011, 08:55 PM   #5 (permalink)
View 96coroll's Photo Gallery
4: Profit
Haha ya that should work actually
96coroll is offline   Reply With Quote
Old 04-19-2011, 07:18 AM   #6 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
-SP
Not always true, sometimes the HB can get stuck on there fairly well with time/age/heat cycling.
Using the starter trick can be dangerous if something slips out of place you have a breaker bar flinging around your engine bay...
Bitter is online now   Reply With Quote
Old 04-19-2011, 07:16 PM   #7 (permalink)
kevdude's Avatar
View kevdude's Photo Gallery
It works every time...I've done it on all my vehicles. Just be sure it's wedged against something solid (like the pavement) and bump the starter. Then just use a little blue locktite on the threads of the bolt when putting it back on. Never had a problem....
97 Avalon XL, 198,000 miles and still going!
06 Solara SLE convertible
kevdude is offline   Reply With Quote
Old 07-03-2011, 03:57 PM   #8 (permalink)
View Flyboy27's Photo Gallery
I tried the bumping the starter trick to get the bolt loose today, bumped it once, and now nothing, no lights, no starter, no nothing. What did I blow?
Flyboy27 is offline   Reply With Quote
Old 07-03-2011, 07:24 PM   #9 (permalink)
Check the battery terminals first. My car was notorious for giving me a "click" when I tried to start it. Make sure they're clean and tight, and check the grounds on the engine block. If all else fails, check the big fuses and relays. Not sure on Toyota but Hondas have a main fuse that likes to act up.
1994 Corolla
Base/1.6 5spd
Old 07-03-2011, 10:00 PM   #10 (permalink)
Checked the terminals and they looked OK, but when I put the leads back on and tightened them up everything worked fine, balancer bolt is now out-
