Rear struts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2011, 09:59 PM   #1 (permalink)
View NWMO 95 Prizm Lsi's Photo Gallery
Rear struts
Good evening,
My next repair will likely be replacement of the rear struts. I've glanced at the Haynes and will look for a DIY thread. I will likely try to tackle this at the boss' shop where air tools are available. I am just working on a daily driver to save gas $$ so nothing high performance is necessary. Any recommendations on what brand and where to purchase? It seems some lower end Monroe struts can be had for about $60/each plus shipping, but I've not looked much.
TIA,
Chris
NWMO 95 Prizm Lsi is offline   Reply With Quote
Old 04-19-2011, 10:06 PM   #2 (permalink)
Thanks Chris !!!
poke here
Old 04-20-2011, 07:26 AM   #3 (permalink)
View 96coroll's Photo Gallery
If your just looking for struts. I've got mine at prime choice auto.com. they are like 30 or something free shipping over 35 dollars. They have complete ones there for like 80. But if you use the complete ones. Warning do not use the nuts that come with the strut. Use your orignal ones. As for me one of the studs stripped. and i changed the top plate with the original one.
But if your just getting struts you won't have this issue because your goin g to use the original top plate prob.
96coroll is offline   Reply With Quote
Old 04-20-2011, 09:39 AM   #4 (permalink)
Thanks 96 corolla,
I will check them out.
Chris
Old 04-21-2011, 01:55 PM   #5 (permalink)
Hey 96 corolla,
Prime Choice appears to be the least expensive when free shipping is considered. Did you get one of their shocks or another brand AND have you been happy with it thus far??
Chris
Old 04-21-2011, 02:53 PM   #6 (permalink)
pdq
Gameroom cash: $220900
View pdq's Photo Gallery
I bought the complete strut assemblies from Prime Choice for my '99 Corolla, which I believe has the same suspension as your generation. I was impressed with the quality and shipping for such a low price. When I pulled my original rear OEM springs off, I could compress them at least an inch by sitting on them, so they were due for replacement.
pdq is offline   Reply With Quote
Old 04-21-2011, 09:31 PM   #7 (permalink)
Gameroom cash: $202300
View zppeacock's Photo Gallery
I have the prime choice rear struts on my wagon. I got the whole assembly. They fixed my rubbing tires from the oem struts with 220k on them. The ONLY bad issue I have with them is that they are louder riding then the oem, but I have a wagon and can hear them easier.
1990 Camry Wagon, 270k, Gray, Retired
1993 Corolla Wagon, 231k, White, w/White Tenzo R's
1994 Lexus ES300, 141k, Pearl White, IS300 Rims
1973 Chevy C20, 76k, Metallic Green, 454 BigBlock
1994 Lexus SC300 1jz 61k Black
zppeacock is offline   Reply With Quote
Old 04-21-2011, 10:01 PM   #8 (permalink)
Thanks guys,
I will give them a shot. Just over $40/side with free shipping is about $20 less than the closest competitor.
Chris
Old 04-22-2011, 06:44 PM   #9 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
KYB are well worth the money.
Monroe arent very good but they do have SOME damping.
Gabriel are to be avoided at all costs. I've had them fall apart.
-SP
Old 04-24-2011, 09:33 PM   #10 (permalink)
on full afterburner
Gameroom cash: $1344797
I would get KYB-GR2 struts off ebay.
Those are the cheapest quality struts out there IMO.
Old 04-24-2011, 11:16 PM   #11 (permalink)
Ok if you get prime choice. DO NOT use the two nuts that they send you if you buy the complete assembly.(As for the third nut there isen't any for the three nut. You have to use the bolt that they give you) As if my case one of the nuts stripped and i ended up replacing it with the original rubber. Which was a pain cause i had to take it apart again. USE the OEM ones.
Part from that i'm happy with the quality they only been on for maybe 10,000 km though.
Oh another issue i had was with the complete assembly on the one side. When i went to put it in the studs didn't line up. one of off by like a mm so i just kinda pryed it over with pilers. But it was very very slight. And that was that. And that was the side that didn't even strip it was the other.
Order brake pads to while you have the free shipping. There cheap. But i have no comments as i've still not put them in.
