thermostat housing nut size - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-01-2011, 07:09 PM   #1 (permalink)
wei
wei's Avatar
View wei's Photo Gallery
Quick question. I was replacing the thermostat today and in the process of putting the housing back on...I dropped on of the nuts into the engine bay
Anyway, do any of you guys know the specs for that nut? I know it's 10mm on the outside, but is there any specifics on inside diameter or can I just go buy a 10mm nut?
Thanks.
1997 Corolla CE - Sold as of 2/2012
2009 Corolla LE
2008 Mazda B2300
wei is offline   Reply With Quote
Old 05-01-2011, 07:42 PM   #2 (permalink)
pdq
Gameroom cash: $220900
View pdq's Photo Gallery
You can get them from any Toyota dealership. Or if you can get the other nut off, I'd bet Home Depot/Lowes will have a matching nut with the same thread pattern.
Also, you should buy a telescoping magnet to help pick up small nuts/bolts.
pdq is offline   Reply With Quote
Old 05-01-2011, 09:14 PM   #3 (permalink)
wei
wei's Avatar
Yeah I'm trying to avoid having to take the other nut off to match. I might just go to Lowes and grab one of every 10mm there is... can't be that many right? And they're probably cheap.
2009 Corolla LE
2008 Mazda B2300
