94 Corolla base model turns but no start..
i cleaned the engine because i had a radiator hose bust and anifreeze everywhere on motor, after rinsing engine and letting it set for a an hour
i went to crank it and it initially started but was running rough and cut off in like 2 seconds, hasnt cranked since then. i have spark at the plugs and even tried a shot of starting fluid and it still want even try to start up. so if i have fuel and fire why want it start? im at a loss as to what it could be, the ECM reads code 1 and nothing else, which is norml, checked each fuse with a fuse checker and inspected all fusible links. swapped out some relays with some i got from a
wrecked corolla and still no start. i initally though i fried something in the distibutor, but like i said i have a spark on all 4 plug wires. even put new plugs in , any ideas?
im in desperate need here, just spent 500.00 on a new timing belt and
water pump, belt job. i need to fix this myself if possible
Reason: too long
