Adding OEM Options, how feasable? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-08-2011, 02:57 PM   #1 (permalink)
Do'er of the Nasty
Kr0n1k's Avatar
View Kr0n1k's Photo Gallery
So, as the fun of having a nearly mint base model Corolla in my possesion has worn off, I'm wondering how easy it is to add factory options? I'd like to have things like power windows/mirrors, rear defrost and (gasp!) intermittent wipers. Anyone have any experience with this?
3 speeds... if only one of them was fast...
Kr0n1k is offline   Reply With Quote
Old 05-08-2011, 04:13 PM   #2 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295773
View Buurin's Photo Gallery
I have done investigations on doing exactly this on an 8th gen.
With enough time and all the factory literature, it can be done.
Variable intermittent is the easiest of these - switch out the combination switch and you're done. At least on the 8th gen.
Power mirrors (PM) is next - find the mirrors and switch, run the wiring. Power mirrors drop right in. Dash should have a place for the switch, taken either by a blank or coin holder. It might even be partially pre-wired.
For power door locks (PDL) and windows (PW) you will need to switch out the interior door panels. With PW all 4 needs changing; PDL the front. Also need to change the actual latches on the doors. Of course, wiring in the door will need to be redone. Also assuming you have no power options, there is possibliity that you will have no holes in the rear door panel for wires to go through. It might be easier to get a door panel with all power options. Integration relay may also be different.
I say get them all. Get FSM and wiring diagrams. Get garage space. Do it in stages. Variable intermittent first as a confidence boost , then PM, then PDL+PW in the front, then PDL+PW in the rear. Scout junk yards for electrical bits. Practice extracting various parts intact. No cutting unless absolutely necessary. As you proceed feel free to come back and ask questions.
Good luck.
Need M12x1.25 tap ASAP!
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
The Following User Says Thank You to Buurin For This Useful Post:
Kr0n1k (05-09-2011)
Old 05-08-2011, 04:46 PM   #3 (permalink)
Do'er of the Nasty
Kr0n1k's Avatar
Thanks Buurin. I was hoping maybe Toyota had wired the cars for all options and just left them out accordingly. The wipers and gauge cluster are going to be first. Manual or not, I like to have a tach. Rear defrost would also be a great add-on... I know, unheard of up north. Needless to say I was confused my self, being from about two hours away from you in upstate NY lol. But Floridians feel they don't need heat or defrorst...
Old 05-08-2011, 06:06 PM   #4 (permalink)
Beware of pigs
Buurin's Avatar
Hit the Thanks button in my post...
Oh for rear defrost you'll need to change out the rear windshield then wire it up. Probably get the switch too.
Buy my parts
Buy my other stuff
Old 05-08-2011, 07:53 PM   #5 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291352
View gold94corolla's Photo Gallery
You are looking at a TON of work man. A TON of work. Did I say a TON of work??
Like Buurin is saying, you've got to basically get another car to swap all the parts over. The DX models have all of this, and if the option was not requested by the owner, the wiring is still there. So like mine, came with everything including sunroof, but no power mirrors?!?! I had all of the wiring there, just had to add the switch and mirrors.
Yeah you are looking at finding a rare intermittent wiper switch, replacing the rear windshield, ripping the dash apart, ripping the doors all apart..... and those power lock actuators and power window motors are a huge pain to mess with because they are sandwhiched inside of the door metals.
gold94corolla is offline   Reply With Quote
Old 05-08-2011, 11:16 PM   #6 (permalink)
Matt94MR2's Avatar
Gameroom cash: $247750
View Matt94MR2's Photo Gallery
I am kind of in the same boat. I have a base model that runs great and is very clean but it lacks all the options. So far I have added the following factory options to it:
1) Intermittent wipers
2) Gauge cluster with Tachometer
3) Power mirrors and switch
4) Trunk light
5) Digital dash clock
6) Center storage console
7) Trunk reflector panel
I am going to attempt the power windows and locks as soon as I can find a suitable donor car at the local pick and pull.
1994 Toyota MR2 Turbo, Gen3 3S-GTE, 278 rwhp, 12.8 @ 106 mph in the 1/4 mile
1996 Toyota Corolla, 4A-FE, 5-speed
Matt94MR2 is offline   Reply With Quote
Old 05-09-2011, 11:29 AM   #7 (permalink)
Do'er of the Nasty
Kr0n1k's Avatar
4) Trunk light
Yea, I mean, it would've been great to find a car this clean with all the options already installed, but it does give me an excuse to spend money on it and play with it. You've got a list that is almost identical to mine and a few local pick and pulls have a ton of these cars so I shouldn't have too much trouble. The worst is most likely the rear defrost. Glass is a PITA.
Old 05-09-2011, 02:11 PM   #8 (permalink)
Gameroom cash: $128158
View jawsofire's Photo Gallery
4) Trunk light
I got a base model too. But mine came with a clock. I also installed a small sunpro tach. Trunk light is really easy to install. I went to a junk yard and got all the parts for about 5 bucks. You need to run your own wiring.
jawsofire is offline   Reply With Quote
Old 05-13-2011, 08:35 PM   #9 (permalink)
Corollas came without a trunk light??? what lol? At least that is an easy addition. Same with the center storage armrest and the trunk reflectors. Even the OEM tachometer is very easy to install.
Old 05-20-2011, 07:31 AM   #10 (permalink)
CLK700's Avatar
View CLK700's Photo Gallery
can i request picture of the intermittent wiper switch / stalk... thanks
CLK700 is offline   Reply With Quote
Old 05-20-2011, 06:09 PM   #11 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Old 05-21-2011, 10:15 AM   #12 (permalink)
CLK700's Avatar
thanks scott for the pic... but i need the LHD one if theres any... thanks
Old 05-22-2011, 08:54 AM   #13 (permalink)
Do'er of the Nasty
Kr0n1k's Avatar
Looks identical. Just on the other side.
Old 05-22-2011, 08:35 PM   #14 (permalink)
CLK700's Avatar
thank you very much... i hope i can find one...
Old 05-23-2011, 04:05 AM   #15 (permalink)
View ahmedsalem89's Photo Gallery
is the intermittent wiper switch plug and play? I'd like to replace the normal one with this and I think I Saw a LHS somewhere around here but I was wondering if it would be fully functional?
ahmedsalem89 is offline   Reply With Quote
