DIY: AE101/ 111 Rear Lower (2 points) Bar install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-08-2011, 04:21 PM   #1 (permalink)
4afte FTW
pnyk33's Avatar
View pnyk33's Photo Gallery
Thumbs up DIY: AE101/ 111 Rear Lower (2 points) Bar install
Just got the Ultra Racing Lower 2 point bar that goes under the back of the car or.................................A lower arm bar is an alloy/steel bar that ties the lower suspension pick-up points of a vehicle (with an independent suspension) together. It increases chassis rigidity by bracing the left and right lower-control-arm sheet metal mounting points. The lower arm bar is designed to reduce the non-pivoting movement of the control arms and to stiffen the subframe to lessen the distortion of the lower suspension, especially during hard cornering. As a result, it improves the handling and steering response of the vehicle much like a strut bar. A lower arm bar provides additional benefits in front-wheel drive vehicles by reducing wheel hop and torque steer. The bar lowers ground clearance by approximately 30 millimeters on most aftermarket installations.
Ok here we go on this. first lift your car up on jacks. you will need a 19mm wrench and Air Gun with 19mm socket.
In the next 3 pics you will see the oem washer and a 5/8`s washer. you can not use the oem for its to large. go to Home depo or lowes to get the 5/8`s grade 8 washer . WHY ? Grade 8 is very strong metel and wont rust or bend when you tighten the strut bar on to the cross arms. Note: dont be CHEEP this only cost $1.25 and well worth it.
After you put in the new washers , just slide the bolt back through and tighten it back down and your done.
hope this can help some one and be moved in the DIY Thread.
My next DIY will be.........
as soon as it gets here.
300 HP 4afte
pnyk33 is offline   Reply With Quote
