Velocity Stacks on a 7AFE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-09-2011, 01:35 AM   #1 (permalink)
96 prizm LSI
View JDMprizm's Photo Gallery
Has this been done?
I would like to do it, but what do I need to take into consideration?
I know this is vague but I don't know much about them.
JDMprizm is offline   Reply With Quote
Old 05-09-2011, 07:31 AM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
ITB's would not be worth it, the cams and head itself will impede flow before the manifold does.
Old 05-09-2011, 09:02 AM   #3 (permalink)
on full afterburner
Gameroom cash: $1345097
AFAIK, it's never been done before.
If you want ITB's just get a 4A-GE 20V swap. You'll get a nice boost in power over the stock economy engine as well.
Old 05-09-2011, 11:36 AM   #4 (permalink)
Do'er of the Nasty
Kr0n1k's Avatar
View Kr0n1k's Photo Gallery
Frankenstein. Add the entire 20V head with ITB's.
3 speeds... if only one of them was fast...
Kr0n1k is offline   Reply With Quote
Old 05-09-2011, 08:08 PM   #5 (permalink)
4afte FTW
pnyk33's Avatar
View pnyk33's Photo Gallery
Originally Posted by JDMprizm View Post
Has this been done?
i havent seen a 7a but there is a 4a with them.
300 HP 4afte
pnyk33 is offline   Reply With Quote
Old 05-09-2011, 09:58 PM   #6 (permalink)
96 prizm LSI
Sell me your 4afte!
and so stacks will work with my car? do i need a certain size?
Old 05-14-2011, 04:23 PM   #7 (permalink)
kor-ro-ra?
midnightmach's Avatar
View midnightmach's Photo Gallery
RIP Corolla & Camry.
midnightmach is offline   Reply With Quote
Old 05-14-2011, 05:32 PM   #8 (permalink)
Bitter's Avatar
sounds like it has no torque. Would like to see the dyno since I know what a 7A should make.
Old 05-15-2011, 12:30 AM   #9 (permalink)
TIEyota fighter ace
Piloter's Avatar
Gameroom cash: $142700
View Piloter's Photo Gallery
Good god, I hope there's at least stacks on those quads and that they shimmed the hood (old-school trick) to get some more air in there. It always seemed nonsensical to me for the Toyota crowd not to be running an airbox when the FWD mounting has the intake at the back and against the firewall.
Makes me almost envy the Neon guys.
Edited to add a little more information: The ST/BT throttles were what, 46 and 48mm? You wouldn't want anything under 40mm, that rules out a lot of bike throttles, and the longer stacks/intake runners you can get, the more usable power you'll actually see. Go look up Helmholtz resonance. You won't fuel them with the stock ECU, too many midrange fuel changes and a positive bloody nightmare to do IAC with unless they're equipped for it already. A LOT of the Honda folks have tried motorcycle quads and there's a wealth of information out there.
(For reference, the set of throttles i have within arm's reach are from the GSX-R 750, Factory Pro stacks, custom T3 remachined adapter...and they were used on an otherwise stock bluetop to great effect.)
WIP AE102.
Piloter is offline   Reply With Quote
Old 05-15-2011, 08:25 AM   #10 (permalink)
Bitter's Avatar
and forget about getting steady vacuum for anything that needs it unless you built a vacuum tank or get an electric vacuum pump with tank...
Old 05-16-2011, 05:11 PM   #11 (permalink)
4afte FTW
pnyk33's Avatar
Originally Posted by midnightmach View Post
Like to see how his turns out, on mine got them all running right and at the same % when not Boosting. other then that wouldnt know how mine are sence my car is Forced Induction.
300 HP 4afte
Old 05-18-2011, 06:51 PM   #12 (permalink)
corolla96's Avatar
View corolla96's Photo Gallery
i have heard that ppl in macau use aftermarket integras' itbs.
K&N SRI, TRD FSB, Magnum Steel Braided Brake Hoses, Depo Black Housing Headlights Set, Clear Signal Lenses, 9006 6000K HID, LED corner lights, lic. plate lights, trunk lights, Ractive Sport Pedals, 20% tint front, 5% tint rear, Freeway TCD-0361-1 Deck, custom front grille
corolla96 is offline   Reply With Quote
Old 02-14-2012, 10:13 PM   #13 (permalink)
View Drextacy's Photo Gallery
hello im only a n00b here but im trying to make sense of the above?
  1. FWD has the intake at the back?
  2. 2makes me almost envy the neon guys?
  3. otherwise stock bluetop ( i have the 7afe. 16v?)
Drextacy is offline   Reply With Quote
Old 02-15-2012, 12:45 AM   #14 (permalink)
Token Aussie
Hiro Protagonist's Avatar
Gameroom cash: $179000
View Hiro Protagonist's Photo Gallery
1. Toyota A-series engines have the intake on the left of the engine (when looking from the timing belt). In a FWD layout, this means the intake is at the back of the engine bay next to the firewall. If you are running velocity stacks and no airbox, there isn't great airflow to the area and it'll be quite warm too. Some other manufacturers (and some other Toyota engines) have the intake on the other side of the engine (so that it's at the front of the engine bay), which gets better airflow.
2. The Chrysler/Dodge Neon is an example of a car of similar size/age to the Corolla with the intake at the front.
3. Bluetop = gen1 16v bigport 4AGE, so-called because the writing on the cam covers was blue. Since you're also from Oz, it's the engine that came out in the AE82 Twincam.
Charlene - 1997 AE102 sedan: FXGT of awesome
Billie - 1981 KE55 sedan: GOOOONNNE
Rosie - 1986 AE82 Twincam Seca: Converted into garage space
Charlie - 1988 ST62 liftback: Moored in the garage
Lexi - 1995 JZZ30 GTTL: Hunting n00bs in Skylines and SS Commodores
Hiro Protagonist is online now   Reply With Quote
Old 02-16-2012, 08:27 PM   #15 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
20V ITB's...just makes sense
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
