Code Deciphering - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-09-2011, 02:19 AM   #1 (permalink)
View eguzman05's Photo Gallery
Code Deciphering
Hi, I have a video of a couple of codes but the thing is I don't know why the o/d off light flashes as well.
It's from a 93 Corolla 1.8L engine.
Any helpful information would be appreciated.
Thanks
eguzman05 is offline   Reply With Quote
Old 05-09-2011, 11:43 PM   #2 (permalink)
View NWMO 95 Prizm Lsi's Photo Gallery
Not sure why the o/d light is blinking "42" as well, but I assume you are figuring out why you lost RPM and VSS data to the ECM? Good luck.
Chris
NWMO 95 Prizm Lsi is offline   Reply With Quote
Old 05-10-2011, 01:52 AM   #3 (permalink)
Thanks. i forgot to mention my speedometer doesn't work. it doesn't mark the correct speed.
Old 05-10-2011, 08:31 AM   #4 (permalink)
eguzman05,
With codes indicating periods of no data for the speed sensor and RPM sensor, it would seem logical your speedometer wouldn't be working either. Trouble shoot starting at your sensors to find the problem. If you don't have a manual, get a Haynes, Chiltons, etc.
Chris
Old 05-10-2011, 02:19 PM   #5 (permalink)
Turk
View blumonster's Photo Gallery
Haynes says 'check Vehicle Speed Sensor, wiring between VSS and ECM, combination meter' for code 42 (4flashes, pause, 2 flashes).
blumonster is offline   Reply With Quote
Old 05-17-2011, 01:03 PM   #6 (permalink)
Update
Replaced the VSS and sure enough it fixed both codes, but not the speedometer.
Old 05-17-2011, 02:53 PM   #7 (permalink)
Turk
Good to hear it solved your problem.
How much did the VSS cost? Is it OEM part or aftermarket?
Old 05-18-2011, 02:09 PM   #8 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Both the engine AND transmission need vehicle speed to make them both operate correctly.
If you speedo doesnt work, its probably the speedo iteself. Change it or the cluster.
-SP
Tags
code, diagnostic, o/d off
