replacement engine installed. from 36 to 27mpg - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-10-2011, 06:47 PM   #1 (permalink)
View yoshiki2's Photo Gallery
What can I check? Engine is 1.8. 190 183 185 192 are the compression levels in cold engine. And it. Doesn't burn any oil. Ideas?
yoshiki2 is offline   Reply With Quote
Old 05-12-2011, 05:51 AM   #2 (permalink)
could be possible that the timing is wrong? my friend told me to check the timing. to buy a digital timing light (gun) and use it to see the motor grades...
Old 06-24-2011, 06:58 PM   #3 (permalink)
Hilux lover
View Kevinpiersonandson's Photo Gallery
gen 7
what is it idling at... I've had bad thermostats that cost me about that much in fuel as it idles too high. (it thinks it's cold all the time) I know that sounds silly, but you may be surprised at the results. Also there is a small pathway between the air intake and the EGR valve that gets clogged up with carbon.
Kevinpiersonandson is offline   Reply With Quote
