what is this part called??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-14-2011, 10:51 PM   #1 (permalink)
View abdurahman's Photo Gallery
I went to a shop to get an alignment cause my car was veering to the right, but then he wouldn't do it and he showed me that this part in the rear suspension was bent. I just want to know, what is it called so I can maybe order it or something, and would it be a relatively easy diy? thanks!!
the guy at the shop couldn't tell me what the part was called cause he only spoke spanish
btw it's the straight one that doesn't have the bolt, it's closer to the front i guess.
you can see the bend on the first picture, near the right
it's a 1993 corolla dx
I really want to know what that part is called so I can see how much it costs, thanks!!
abdurahman is offline   Reply With Quote
Old 05-15-2011, 12:42 AM   #2 (permalink)
anyone? It's not a tie rod right? The tie rod is the one with the threading? I wanna know if this part is dangerous to drive on? I drive 100 miles a day 2 days a week and I don't want to get stuck on the freeway so I really want to know what that part is. thanks!
Old 05-15-2011, 12:42 AM   #3 (permalink)
pdq
Gameroom cash: $220900
View pdq's Photo Gallery
That's a rear suspension arm. You should get one from a junkyard, as the Toyota dealers will charge at least $150.
FYI, you can go to toyotapartszone.com, then click on your car/model, and then Power Train => Rear Spring & Shock Absorber, and you can get a diagram/parts list:
http://www.utoyot8.com/FullImage.asp...(9209-++++)NAP
pdq is offline   Reply With Quote
The Following User Says Thank You to pdq For This Useful Post:
abdurahman (05-15-2011)
Old 05-15-2011, 12:47 AM   #4 (permalink)
oh my god thank you so much I kept looking online and I could not figure out what it was! My and my dad will go to the junkyard tomorrow, is it easy to remove? what parts do I need to remove it?
Thanks!
Old 05-15-2011, 12:55 AM   #5 (permalink)
pdq
Pretty easy. Assuming you have jacked it up in the air and on jack stands, you just need a metric socket set. There should be just two bolts to remove. It may help to take the left tire off, but you might be able to do it without removing it.
I think has about 100 pounds of torque on it, so you may need a 2 foot breaker bar or cheater pipe to get enough torque to break the bolts loose.
PS: make sure you use 6 point sockets, and not 12 point sockets, as you can round off the nut with 12 point. And Harbor Freight is a great place for cheap tools if you don't have any.
Old 05-15-2011, 12:58 AM   #6 (permalink)
thank you so much, you are a lifesaver!
also, that website is really helpful, thanks!
Old 05-15-2011, 01:11 AM   #7 (permalink)
pdq
Happy to help. Good luck with the repair.
Old 05-15-2011, 10:25 AM   #8 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
You have a doofus for a mechanic. The bar can be EASILY straightened without compromising structural integrity. I hope you junk yard trip was sucessful and your car gets fixed properly.
-SP
Old 05-15-2011, 01:01 PM   #9 (permalink)
noo, I was just at a random alignment shop, my mechanic is closed on weekends, he is awesome
Old 05-15-2011, 01:46 PM   #10 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291352
View gold94corolla's Photo Gallery
perhaps go to your mechanic first then.
gold94corolla is offline   Reply With Quote
Old 05-15-2011, 04:38 PM   #11 (permalink)
alright I went to the junkyard and I got that thing for 7 dollars haha! Sure beats the $150 from the dealer! It was pretty easy to remove, all I had to do was unscrew the nuts for the tie rod on the other side and it slid right out. Thanks for the help guys!
Old 05-15-2011, 05:44 PM   #12 (permalink)
Andele, andele!
speedy25's Avatar
I like it when a job is easy. In the midwest thats an all day job trying to conquer the rust monsters!
-SP
Old 05-15-2011, 07:36 PM   #13 (permalink)
haha yeah, luckily I live in CA, where rust doesn't exist!
