Hi, I am here to help you. I am an expert in HIDs, projectors, head lights, etc (among other things
First, stay far away from blue lights. You will not be able to see anything at night. The blue color is bad for night vision, plus blue lights are always dimmer than white ones. But I agree that the yellow halogen color, especially out of these lights, is not good visibility, either. I recommend 5000K color, as it is pure white in these head lights. If you must have a bluish look, then go with 6000K. It will be dimmer though.
Also, stay far away from blue-coated halogen bulbs. These are a joke and a scam.
So your best option is an HID kit in these projectors. When done right, it will have little glare and a useable light on the road (although nowhere near as nice as cars with factory HID projectors).
You will buy the H1 HID kit. NOT 9006. The H1 bulb needs to fit into the projectors. The ballasts come with two pins that you can insert into the stock 9006 connector. Here is a picture showing the HID kit.
In this next picture, you can see in the background the HID bulb in the head light (different lights) but more importantly, you can see the pins inserted into the head light connector.
However, instead of simply inserting the pins into the head light sockets, you should install a relay wire harness. Just like an amplifier wiring kit, this will draw power directly from the battery to power the HIDs, rather than drawing power through the head light connectors. This will save your stock wiring, connectors, switches, since HIDs have a huge startup current. This will also ensure that your HIDs turn on without flickering.
To get the HIDs to fit in the projectors, you will need to grind out the side of the opening, similar to here:
This way the return wire on the bulb will fit through. You might also need to adjust the metal shield inside to get a good cutoff. You might need to modify the bulb seating as well to get the focal point exactly right. But when you are finished, your lights should look like this (5000K color)
Hope this helps everyone.
Feel free to view more pictures and information here
http://www.cardomain.com/ride/801395...edan-4d/page-6
