High Beam toggle wont work - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-16-2011, 03:47 AM   #1 (permalink)
View delgadomj's Photo Gallery
Pushing the toggle forward to "lock" the high beams on doesn't work. However, pulling the toggle back to "flicker" the high beams on and off does work. It sucks not being able to use your high beams. Its probably a connection issue. Please help, thanks.
delgadomj is offline   Reply With Quote
Old 05-16-2011, 04:36 AM   #2 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
The exact same thing happened to me a few months ago. I tried to fix the switch but wasn't successful, so ended up buying a replacement combination switch from a wrecker. You could either do what I did and replace the whole thing, or you could just replace the headlight stalk, although this requires a lot more effort since you have to remove the pins from the electrical connector. Alternatively, you could remove the switch and see if the contacts are making a proper connection.
Old 05-19-2011, 08:05 PM   #3 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291352
View gold94corolla's Photo Gallery
yeah, you are going to need to replace the switch/stalk if you can't clean up the connections.
gold94corolla is offline   Reply With Quote
