Routing brake lines, need help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-27-2011, 07:56 PM   #1 (permalink)
View boohoops's Photo Gallery
Question Routing brake lines, need help!
Hey everyone, new guy here. Anyways i just scored a 1995 corolla for dirt cheap. only issue is that the rear brake lines, the hard ones, were both rotted and leaking. previous owner started to remove em and wound up cutting them half way, leaving the front half of th line from the proportioning vale still there. once i got the car, i removed the lines completely and just got the brand new pre-bent ones. However, i cant quite seem to figure out how to route the lines around the fuel tank, rear sway bar, etc. anybody with some sketches/doodles or under car images would be great! the pic i have from alldata (got it from a local mechanic) shows the lines and nothing else, basically just a parts number reference. any help would be greatly appreciated! need to get this thing on the road asap!! TIA!!
boohoops is offline   Reply With Quote
The Following User Says Thank You to boohoops For This Useful Post:
blb (06-05-2011)
Old 05-28-2011, 04:18 AM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Sorry I didnt take any pics when I did this job a short while back. You'll have to do some bending to get those pre-bent lines in place but it can be done. This car was one of the more difficult ones I have done due to all the bends in the lines.
-SP
Old 05-28-2011, 12:32 PM   #3 (permalink)
Yea I think i may have figured it out partially, but I'm not a hundre percent sure how it's supposed to come out on th right rear to th drum itself. And do u remember if th lines went over or under that front left corner of th gas tank? Thanks speedy
Old 05-28-2011, 12:37 PM   #4 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
Honestly I've always thought it was easier to get the lines in a roll and just bend your own. As long as they're away from moving parts and tucked away so they're not the low point you're fine.
Old 05-29-2011, 09:15 AM   #5 (permalink)
View rafaespin's Photo Gallery
1995 dx the same problem here............. $$$140 to fix this problem
rafaespin is offline   Reply With Quote
Old 05-29-2011, 12:01 PM   #6 (permalink)
Do u happen to have any pics of the line at the rear end of the car?? U would be my hero if ya did!
Old 05-30-2011, 03:24 PM   #7 (permalink)
Even just some pics of the lines at th rear wheels would work. And to rafaespin, do u remember fifth lines went over or under th gas tank?
Old 05-30-2011, 06:50 PM   #8 (permalink)
let me show you is not a professional work but this or no breaks.....
Old 05-30-2011, 07:24 PM   #9 (permalink)
Old 06-05-2011, 04:16 PM   #10 (permalink)
blb
View blb's Photo Gallery
Originally Posted by boohoops View Post
Once i got the car, i removed the lines completely and just got the brand new pre-bent ones. TIA!!
Where were you able to buy the pre-bent brake lines?
blb is offline   Reply With Quote
Old 06-05-2011, 11:53 PM   #11 (permalink)
I used to work at a garage so I had the mechanic there order it for me. Think he got em from th stealership
