Hi Mates! Im new to the ToyotaNation board.
Hope I could get some guidance on my problem that I've been facing.
Back in January I changed the clutch, bearing, pressure plate (the whole lot) on my Corolla AE101. The stuff were from Aisin. Ever since then I've been having this random "judder" from the engine whenever the engine is on idle, and the clutch depressed while in first gear after a long drive through traffic.
scenario (in sequence):
- you are in a jam, and you have first gear engaged, so you crawl through the jam.
- when the car in front stops, you depress the clutch pedal to free (BUT you are still in first gear).
- the engine would judder sometimes. Its like the gear is not totally free and it keeps tugging at the car.
- Solution is to pull the gear out from 1 to neutral, and it will be gone.
But at anytime the car is moving, there's no problems whatsoever. No slips, no knocking noises, nothing.
Any ideas? It would not happen all the time. just that it would likely happen when it gets hotter? (usually after a long drive). I have changed the clutch pumps last week, but it still happens.
I took it to the mechanics but I couldn't replicate the problem on the spot.
It's making my drive very frustrating. Any help would be greatly appreciated
