engine interchangeability question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2011, 11:13 PM   #1 (permalink)
View 03keen's Photo Gallery
hi,
i have a 93 corolla and the block has a bad main bearing. im gonna get a replacement japanese imoprt motor for 425 delivered. i think my car has the 1.7 or 1.8, how can i tell.
the one i can get its a 1.6, is that going to be compatible with my transmission/motor mounts/etc...? and will all the sensor plugs fit my harness? its from attarco here in sacramento, motor has 60k or less miles on it.
i plan on doing the water pump, timing belt, clutch, RMS and tune up stuff when i get it. any other suggestions?
thanks
joaquin
03keen is offline   Reply With Quote
Old 06-08-2011, 04:08 AM   #2 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Welcome to the forums. Right now your Corolla will either have a 1.6L 4A-FE or a 1.8L 7A-FE. The best way to check which engine you have is to look at the engine code that's etched into the block. It's located to the right of the exhaust manifold and is stamped vertically.
Here's some photos of it's location:
As you can see, mine says 5A as it has a 5A-FE engine. It will says 4A for the 4A-FE or 7A for the 7A-FE. You will have to get down low to see the numbers on the block and may have to give it a bit of a wipe to get rid of any dirt etc, but this is the most reliable way of checking which engine your car has.
As for the wiring, the 1.8L 7A-FE has a knock sensor whereas the 1.6L 4A-FE does not, so the loom is slightly different between the two. The ECU will also be different. The engine mounts are the same however and the transmissions are interchangeable. In regards to getting a JDM engine, bear in mind that the JDM engines didn't have an EGR system as the emissions standards were different between the US and Japan, so if your engine currently has an EGR system then that's something to bear in mind.
I'd suggest replacing the motor with one that is identical to the one you're taking out, just to avoid any problems and additional cost. Most wreckers or junkyards should be able to sell you a replacement engine as both the 1.6L and 1.8L are very common. Good idea to do the timing belt replacement while the engine is out. It would be best to also replace the rubber hose that leads from the water pump to the block. Replacing the valve cover gaskets is a good idea too, but this is an easy job and can be done once the engine is fitted if need be.
Old 06-08-2011, 06:01 PM   #3 (permalink)
nice info. thanks, i actually can only make out the A on mine... but some looking around let to the catalyst under the hood and it says 7afe. and i found a motor thru engine world usa for 550. he said less than 50k on it and it is drilled and taped to accept the egr system. so it will be california legal after the install. if i run into any bumps during my motor change i know where to go now that im on the forum.
