Engine turns-off unexpectedly
Hi all,
Sorry for the long post....
Needs some help/direction from the board members please.
Here is the info:
1996 Corolla Auto with 220K on the clock
Car has been great until about a month ago when one morning it did not want to start.
Engine turns over but it would not start.
Had it towed and a new complete distributer was replaced.
Ran ok for 1-2 weeks, and then again the same problem accrued. For no reason at all, it will not start.
After several more towing sessions to the garage, they could not diagnose the problem. It seems it is sporadic. Leave it for a while, and it will start up again.
This time I had it towed to a different garage, unfortunately they could not diagnose the problem either due to it working again.
Moving ahead, not only does it not want to start first thing in the morning, but it is starting to turn its self off while you are driving it (very dangerous).
This morning it did not want to start up again (cranks fine but no joy).
After searching and reading the forum, I decided to do some of my own investigating.
With the key in on position, I found out that I was not getting any power to the distributor.
Check all fuses and they all seem ok...including the AM2.
I don’t want to have it towed again (I believe this will be the 6th time) and only to find out that it all works again. Not only that, car is not very safe to be driven this way.
What would you recommend that I check next? Any ideas?
Is there a relay or something else that might be causing this intermittent problem?
All input/recommendations are graciously received.
Again, sorry for the long post....
Phil
