93 Corolla Exhaust - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-11-2011, 05:58 AM   #1 (permalink)
View 95rolla95's Photo Gallery
93 Corolla Exhaust
Hi, I'm new to the forum.
My son has a 93 Corolla, 1.6L, 5 speed, 2 door, all stock.
It appears to have an exhaust leak from the joint between the catalytic converter to the muffler. I can't tell if the joint is bolted. The "bolts" don't have much of a head on them.
Should I be able to separate the joint and put in a new gasket? How? I don't have a torch. I'm thinking of unbolting the whole thing from converter inlet back to work on it, but the converter inlet joint bolts are very rusted.
Thanks,
Brian
95rolla95 is offline   Reply With Quote
Old 06-11-2011, 11:18 AM   #2 (permalink)
View lrak's Photo Gallery
If I remember correctly, there are bolts that go through the midpipe flange and into nuts welded onto the muffler flange. I ground off the heads of the bolts with a dremel, removed the muffler, and drilled a slightly larger diameter hole through the nuts. I then reassembled with stainless nuts, bolts, and washers from the hardware store.
lrak is offline   Reply With Quote
The Following User Says Thank You to lrak For This Useful Post:
95rolla95 (06-14-2011)
