Originally Posted by cipher93
The first time, it sounds like he used the sender unit from a non tach car in a car with a tach (or vice versa). As for the light not coming on, it could be a fluke, but have you made sure the bulb didn't burn out? It would be an odd coincidence but is possible. I just want to know why your mechanic replaced an apparently working sender, especially with USED ones.
Thanks for your input Cipher. How do I check if the bulb is burned out (although as you said that would be quite a coincidence)? Also, do you know how this light is activated - does it have its own sensor in the tank, or is it triggered by the fuel gauge?
Good question about the sender unit, I thought about that myself. When I asked the mechanic why he replaced the original sender unit, he said the old unit and my old tank were heavily rusted and had gotten fused together that he could not reuse the sender unit, does that make sense (I have very limited knowledge in this topic)?
